Use Custom Embedded Cursor - User Interaction Event
matt_jlt
matt_jlt
Can anyone tell me how to use an embedded cursor (mycursor.cur) via the SetCursor command under user interaction events. I can use built in cursors just not able to get it working with my resource.
Sample below throws an error type mismatch.
oInteraction.SetCursor(CursorTypeEnum.kCursorTypeCustom, My.Resources.mycursor)
I have set the build action of the cursor to be embedded.
Win7
Inventor 2014
VB.Net
Thanks, Matt.
xiaodong_liang
Autodesk Support
Autodesk Support
matt_jlt
I have tried that method before but the issue is that the cursor I have is an internal (embedded into the dll) resource.
What i have done as a work around is to check if the cursor already exists in the application data directory, if not write the embedded cursor to the application data directory and point my custom cursor to that.
My main intention is to have my addin require no additional files to go along with the dll. I guess this will have to do until inventor supports the use of internal / embedded resources.
e.g My.Resources.myCursor.cur
thanks, Matt.
xiaodong_liang
Autodesk Support
Autodesk Support
yes, I also used the additional cursor files. The way to embed the cursor to the resource does not work.
