Update
Update
Update
So I made an excel file to drive a part, ilogic pulls in the numbers, then I made a rule to make a drawing.
I made a hyperlink on the excel sheet to open up the model, the model reads the updates and then the drawing is launched. However the drawing does not reflect the last changes made, if I click on the model it reflects the updates and then if I click back over to the drawing it is updated.
Is there a way to have the drawing update immediately?
Also is there a way to make it so that the new drawing has the title of the PN?
Stakin
try :
Imports Inventor.ViewOrientationTypeEnum
Imports Inventor.DrawingViewStyleEnum
Dim oDrawDoc as DrawingDocument
Dim oPartDoc as Document
Dim oSheet As sheet
Dim oTG As TransientGeometry
Dim oBaseView As DrawingView
Dim oView2 As DrawingView
ViewScale = 1/16
'Ask To create drawing?
dwgQuery=MsgBox("Would you like to Create a drawing for this MODEL?", vbYesNo,"Drawing Selection")
If dwgQuery = vbYes Then
    oPartDoc = ThisDoc.Document
    'Define IDW Template File Location
    oDrawDoc = ThisApplication.Documents.Add(kDrawingDocumentObject, "L:\Template.dwg", True)
    oSheet = oDrawDoc.Sheets.Item(1)
    'Define 2d view bottom Left corner points For four views
    oPoint1 = ThisApplication.TransientGeometry.CreatePoint2d(37, 23)
    oPoint2 = ThisApplication.TransientGeometry.CreatePoint2d(18,15)
Dim oBaseViewOptions As NameValueMap
oBaseViewOptions = ThisApplication.TransientObjects.CreateNameValueMap
'True = folded view
'False = flat pattern view
oBaseViewOptions.Add("SheetMetalFoldedModel", False)
oBaseView = oSheet.DrawingViews.AddBaseView(oPartDoc,oPoint1, 1/25,kIsoTopRightViewOrientation, kHiddenLineRemovedDrawingViewStyle, "Default")
    oView2 = oSheet.DrawingViews.AddBaseView(oPartDoc,oPoint2, 1/8, kFlatPivotRightViewOrientation, kHiddenLineDrawingViewStyle,,, oBaseViewOptions)
Parameter.UpdateAfterChange = True
MultiValue.UpdateAfterChange = True
iLogicVb.UpdateWhenDone = True
oDrawDoc.Update()
That still did not autoupdate the drawing. It does still update if I swithch screens back to the model though
philippe.leefsma
Did you try calling Update() on the PartDocument?
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
Stakin
I think you can add a rule to Update the drawing,triggered by the model save action after you changed the excel sheet.
like this:
Dim oDrawDoc As DrawingDocument
Dim oTpDoc As Document
Try
 oDrawDoc=ThisApplication.Documents.ItemByName("C:\XXXX\XXX.idw")
 oDrawDoc.Update()
oDrawDoc.Save
Catch oDrawDoc = ThisApplication.Documents.Open("C:\XXXX\XXX.idw",false) oDrawDoc.Update() oDrawDoc.Save
oDrawDoc.Close End Try
"C:\xxx\xxx.idw" is your drawing file location
Maybe it works.
