Use an option of the helicoid function with iLogic
jgomis.ext
jgomis.ext
I would like to select with iLogic the rotation way of my helicoid function to control it in a form.
Do you have any ideas of how to do it ?
Thanks 🙂
dalton98
try this
Dim oList As New ArrayList
oList.Add("Left")
oList.Add("Right")
inputvalue = InputListBox("Select rotation", oList, "Left", Title := "Title", ListName := "List")
Dim oDoc As PartDocument = ThisDoc.Document
Dim oFeature As PartFeature
For Each oFeature In oDoc.ComponentDefinition.Features
	If oFeature.Type = kCoilFeatureObject
		Dim oCoil As CoilFeature = oFeature
'		oCoil.ClockwiseRotation = Not oCoil.ClockwiseRotation
		If inputvalue = "Left"
			oCoil.ClockwiseRotation = True
		Else If inputvalue = "Right"
			oCoil.ClockwiseRotation = False
Next
WCrihfield
Hi @jgomis.ext.  That dialog looks like the dialog for creating a coil feature in a part.  And the controls you have circled are basically just represented by a Read/Write Boolean type property in the CoilFeature object named ClockwiseRotation.  This property is False by default, which means that it would be counter-clockwise rotation, instead of clockwise rotation.  When I hover those two controls with my mouse, their tool tip says either Left Hand, or Right Hand, and right hand would mean clockwise rotation, because that is the direction that the hands on a clock rotate.
Wesley Crihfield
(Not an Autodesk Employee)
jgomis.ext
I have 3 helicoids function in my part. Do I have the possibility to do it for only one of my function ?
dalton98
@jgomis.ext
You would need to get rid of the for loop and set the feature object to that specific one
oFeature = oDoc.ComponentDefinition.Features.Item("Helicoide2")
WCrihfield
Just another possible way, which prompts the user for each one found in the current part, and shows the feature's name for each.  I haven't tested this yet, because I don't have a part with multiple coil features in it right now.
Dim oPDoc As PartDocument = ThisDoc.Document
Dim oPDef As PartComponentDefinition = oPDoc.ComponentDefinition
Dim oCFs As CoilFeatures = oPDef.Features.CoilFeatures
If oCFs.Count = 0 Then
	MsgBox("No CoilFeatures found. Exiting rule.", vbExclamation, "")
	Exit Sub
For Each oCF As CoilFeature In oCFs
	bBool = InputRadioBox("CoilFeature named:  " & oCF.Name _
	& vbCrLf & "RIGHT = Clockwise / LEFT = CounterClockwise", "RIGHT", "LEFT", False, "RIGHT or LEFT")
	oCF.ClockwiseRotation = bBool
Next
Wesley Crihfield
