if and then statements
sjoerd.van.der.eerden
hi, i'm making an configurable inventor model with ilogic.
i have two paramerters that controle the same feutures. there are a total of 4 combinations that can be made. but only one of them works. this is the piece of code i used.
If aantal_vulpunten = "1" And leiding_inkomst = "achterkant" Then
     Feature.IsActive("achterkant:1", "Extrusion4") = "true"
     Feature.IsActive("achterkant:1", "Extrusion5") = False
     Feature.IsActive("top:1", "Extrusion2") = False
     Feature.IsActive("top:1", "Extrusion3") = False
ElseIf aantal_vulpunten = "2" And leiding_inkomst = "achterkant" Then
     Feature.IsActive("achterkant:1", "Extrusion4") = False
     Feature.IsActive("achterkant:1", "Extrusion5") = "true"
ElseIf aantal_vulpunten = "1" And leiding_inkomst = "bovenkant" Then
    Feature.IsActive("top:1", "Extrusion2") = "true"
ElseIf aantal_vulpunten = "2" And leiding_inkomst = "bovenkant" then
    Feature.IsActive("top:1", "Extrusion3") = "true"
End
any advise?
thanks in advance.
WCrihfield
Hi @sjoerd.van.der.eerden.  The first thing I am seeing that does not look correct is that you are putting quotation marks around some of your Boolean type values.  When using Feature.IsActive() methods, you need to always set the value as either True or False, and never with "true" in quotes.  If the value is in quotation marks, it is seen as a String instead of a Boolean, so it will fail.
Wesley Crihfield
(Not an Autodesk Employee)
I deleted the quotation marks but that didn't seem to be the problem.
it turned out there was an extra space in one of the names. therfore it dind't recognise it.
aparently a space can cost you an hour of your day.
but thank you for the advise, really appreciate it. 🙂
