Use a parameter with item
TONELLAL
TONELLAL
I have a problem with using a parameter as item("xxx") :
Dim oPart as PartDocument
Dim oRenderstyle as Renderstyle
Dim toto as String
'This is ok :
Set oRenderstyle = oPart.RenderStyles.item("Red")
'This is NOT ok :
toto = "Red"
Set oRenderstyle = oPart.RenderStyles.item(toto)
Could you tell me where is the problem ? Thanks !
wayne.brill
I am not recreating this so far. Below is the VBA code I used. Is there an error?
Sub string_param_test()
    Dim oPart As PartDocument
    Dim oRenderstyle As RenderStyle
    Dim toto As String
    Set oPart = ThisApplication.ActiveDocument
    'This is ok :
    Set oRenderstyle = oPart.RenderStyles.Item("Red")
     'this is ok too
     toto = "Red"
     Set oRenderstyle = oPart.RenderStyles.Item(toto)
End Sub
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
TONELLAL
Effectively, on the first test "toto" was only defined by "dim toto". When specifying "dim toto as string" it is ok !
