urgent: how to register a DLL in windows 10
liminma8458
liminma8458
I have add in for Inventor 2019 pro. It is compiled under net.framework 4.5. It registers fine and work in windows 7 and Inventor 2019. It is compiled under net.framework 4.5. Now I switch to windows 10. it does not register. I am using a bat file :
@ ECHO OFF
C:\WINDOWS\Microsoft.NET\Framework64\v4.0.30319\RegAsm.exe /codebase "C:\Program Files\Autodesk\Macros\UI_Ribbon_Demo.dll"
PAUSE
How to make the registry work in windows 10.
Thank you very much!
Limin
Inventor pro 2023 64 bit update 5.3; Windows 11 pro 64 bit version 24H2; Office 2013 64 bit
Download iCable in App Store to Create Cables Easily
JamieVJohnson2
Isn't Inventor 2019 based on .Net 4.7?
Jamie Johnson : Owner / Sisu Lissom, LLC https://sisulissom.com/
liminma8458
I compile that using 4.5 framework in VB.net. it works fine, although Inventor 2019 uses net framework 4.7. I find the solution: just right click the bat file, "run as administrator".  It is said this is extra security from windows 10
Limin
JamieVJohnson2
I thought the Windows 10 UAC was pretty much the same as Windows 7 UAC.  I guess it's more aggressive.
