Updating Form Fields When Button Clicked
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello all,
So finally at a place that is using Inventor for woodworking and such and im learning pretty quickly how to create forms and rules and i love it. Having issues tho and its probably simple. Im making a simple wood counter, and having an option of removing the toe kick if you want or adding it if its needed. Got all that working just fine.
SyntaxEditor Code Snippet
If ToeKickVisible = True 'This is asking if you want a toe kick, then it will show all visible parts Parameter("oheight") = Parameter("height") + Parameter("ToeHeight") iLogicVb.UpdateWhenDone = True Feature.IsActive("TKick_Front") = True Feature.IsActive("Tkick_left") = True Feature.IsActive("Tkick_Rear") = True Feature.IsActive("Tkick_Right") = True Feature.IsActive("Tkick_Block") = True End If If ToeKickVisible = False 'If there isnt a toe kick, then this will hide the parts and adjust the oheight param call out Parameter("oheight") = Parameter("height") iLogicVb.UpdateWhenDone = True Feature.IsActive("TKick_Front") = False Feature.IsActive("Tkick_left") = False Feature.IsActive("Tkick_Rear") = False Feature.IsActive("Tkick_Right") = False Feature.IsActive("Tkick_Block") = False End If
For the code. I attached a picture of my form as well. There is a field grayed out (intentional) so that if theres a toe kick, it will make sure you are at the height you want to be. Problem is, the oheight form only ever updates after pressing my Toe Kick Button...I know theres an update line i need to add just dont know where to start looking for that..or maybe im looking down wrong path.
Thanks!
