Update value of Title textbox
Hi:
First of all I apologize for my bad English.
I'm trying to adapt a code I've seen updated from the value of a TexBox of Title with the value of the scale of a view.
The problem is not as update the value of TexBox
Option Explicit
Public Sub escala()
Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
Set oSheet = oDoc.ActiveSheet
Dim oTitleBlockDef As TitleBlockDefinition
Set oTitleBlockDef = oSheet.TitleBlock.Definition
Dim oTextBox As TextBox
Dim bFound As Boolean
bFound = False
For Each oTextBox In oTitleBlockDef.Sketch.TextBoxes
If oTextBox.Text = "<ESCALA>" Then
Dim EscalaTitle As String
EscalaTitle = oSheet.DrawingViews.Item(1).ScaleString
'''ERROR
''' I want to pass the value of EscalaTitle to EscalaProp
Dim EscalaProp As TextBox
EscalaProp = oSheet.TitleBlock.SetPromptResultText(oTextBox, EscalaTitle)
'''ERROR
MsgBox "encontrado =block."
bFound = True
Exit For
End If
Next
If bFound Then
oSheet.Name = oSheet.TitleBlock.GetResultText(oTextBox)
MsgBox "Encontrado valor" & oTextBox.Text & oSheet.TitleBlock.GetResultText(oTextBox)
Else
MsgBox "Specified formatted text was not found in the title =block."
End If
End Sub
Thank in advance
YuhanZhang
I test the code with Inventor 2011, and only one line has a trivial issue, that is:
the line is gonna set the sheet name with a string like "1 : 1" which is not supported. Except this issue everything works fine.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
I really want to change is the value of a text prompt called <ESCALA> of the Title and enhance the value of the scale of the first view.
I am working with Inventor 2008
Thanks for everything
