Update style from Library
Hi.
I've some old assembly that I want to update.
Actually I update the styles manualy, but I want to make it with C#.
I do :
1. Update styles, check all, yes for all, OK.
Can I do it with some C# code ?
Best regards.
wayne.brill
Hi Marcelo,
I do not have an example that does this but I believe your code would need to traverse through the components of the assembly and call UpdateFromGlobal for the styles and materials. This post has C# examples.
http://modthemachine.typepad.com/my_weblog/2012/10/c-help-examples-for-assemblies-occurences.html
The example function in that project named AssemblyCount tranverses an assembly.  (does not call UpdateFromGlobal however).
Here is a VBA procedure that can be used for a quick test for UpdateFromGlobal with a sheet metal PartDocument.
Sub SheetMetal_Sytle_Update_Test()
    Dim oPartDoc As PartDocument
    Set oPartDoc = ThisApplication.ActiveDocument
    Dim oSheetMetalCompDef As SheetMetalComponentDefinition
    Set oSheetMetalCompDef = oPartDoc.ComponentDefinition
    Dim oSheetMetalStyle As SheetMetalStyle
    Set oSheetMetalStyle = oSheetMetalCompDef.ActiveSheetMetalStyle
    oSheetMetalStyle.UpdateFromGlobal
End Sub
Here is a VBA example that calls UpdateFromGlobal for materials in a PartDocument.
Sub Material_Update_Test()
    Dim mat As Material
    For Each mat In oPartDoc.Materials
        If mat.UpToDate = False Then
            Call mat.UpdateFromGlobal
            'Debug.Print mat.Name
        End If
    Next
End Sub
This post has information about appearance assets that may help with what you are trying to do:
http://forums.autodesk.com/t5/inventor-customization/updatefrom-global-for-colors-appearances/m-p/64...
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
Thank you Wayne for the feedback.
From what I understand, the example updates the part material.
Is it possible to recursively update all parts within an assembly?
Best regards.
wayne.brill
Hi Marcelo,
Yes it is possible to recursively update all parts in the assembly. The post I mentioned in my previous reply has C# examples. You could start with the AssemblyCount example and update it so that it gets the document for each occurrence and updates the part material. The AsseblyCount example is also in the Programming help so you could do a prototype using VBA and then move it to C#.
Wayne
Wayne Brill
Hi Wayne.
With your tips and another example I found here on this site http://modthemachine.typepad.com/my_weblog/2009/03/accessing-assembly-components.html, I was able to do what I needed.
public void UpdateStyle(Inventor.Application invApp) {
	try {
		AssemblyDocument oAsmDoc = (AssemblyDocument)invApp.ActiveDocument;
		foreach (Document oDoc in oAsmDoc.AllReferencedDocuments) {
			PartDocument oPartDoc = (PartDocument)oDoc;
			Material oMat = oPartDoc.ComponentDefinition.Material;
			if (!oMat.UpToDate) {
				oPartDoc.ComponentDefinition.Material.UpdateFromGlobal();
		MessageBox.Show("OK");
	catch (Exception ex) {
		MessageBox.Show(ex.Message);
Best regards.
freesbee
Hi Wayne,
I am struggling with this issue: I also would like to update local material styles form the library, but I cannot find the "Material" in the API: only the "MaterialAsset" appears to be available, but unfortunately I am not able to find any "UpdateFromGlobal" method for the MaterialAsset.
What am I doing wrong?
Sub updateMaterial()
Dim mat As MaterialAsset
For Each mat In oPartDoc.MaterialAssets
  MsgBox mat.DisplayName
Next
End Sub
Massimo Frison
CAD R&D // PDM Admin · Hekuma GmbH
freesbee
...well, as I wrote before I am not sure that the "material" member exists.
Luckly in the meantime I have found the right solution to this issue, nicely documented by @VGonsalves here:
UpdateFromGlobal for Materials
Thank you so much!
Massimo Frison
