Update or Create Custom iProperty in Sheet Metal Parts from an Assembly
JBerns
Advisor Advisor
JBerns
Community,
My goal is to update three custom iProperties in all the sheet metal parts of an assembly.
If a custom iProperty is missing, it needs to be added and then its value set.
I have evaluated using iLogic at the part level, but prefer to use VBA from the assembly level.
I am using VBA because of its better debugging (learning) interface. Therefore, no Try-Catch clauses, only On Error statements.
The three custom iProperties are:
- Customer: the customer name for the job
- Material: a classification code based on the sheet metal material
- Grade : a classification code also based on the sheet metal material
I am using Brian Ekins' ( @ekinsb ) code to get the references in the assembly.
https://modthemachine.typepad.com/my_weblog/2009/03/accessing-assembly-components.html
This gets all the file references in the assembly, including those in subassemblies.
I am using more code from Brian to update the custom iProperty.
https://modthemachine.typepad.com/my_weblog/2010/02/custom-iproperties.html
The UpdateCustomiProperty code works well when tested in a part document, but fails for me when called from the assembly level. No errors occur, but the iProperty is not added/updated.
Can anyone offer suggestions as to how to modify the UpdateCustomiProperty  code to get the sheet metal part custom iProperties updated/added from the assembly level?
Here is what I have so far:
Option Explicit
Public Sub ProcessReferences()
    'Initialize strings
    Dim strCustomerName As String
    strCustomerName = "NONE SELECTED"  'Simplified here, but normally set through a UserForm
    'Get the active assembly
    Dim oAsmDoc As AssemblyDocument
    Set oAsmDoc = ThisApplication.ActiveDocument
'yes, I will test here to ensure active doc is an assembly
'Get all of the referenced documents Dim oRefDocs As DocumentsEnumerator Set oRefDocs = oAsmDoc.AllReferencedDocuments 'Iterate through the list of documents Dim oRefDoc As Document For Each oRefDoc In oRefDocs 'Test if reference is a sheet metal part If oRefDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then Call UpdateCustomiProperty(oRefDoc, "CUSTOMER", strCustomerName) End If 'Update document oRefDoc.Update Next End Sub Public Sub UpdateCustomiProperty(ByRef Doc As Document, ByRef PropertyName As String, ByRef PropertyValue As Variant) 'String 'Get the custom property set Dim customPropSet As PropertySet Set customPropSet = Doc.PropertySets.Item("Inventor User Defined Properties") 'Get the existing property, if it exists. Dim prop As Property On Error Resume Next Set prop = customPropSet.Item(PropertyName) 'Check to see if the above call failed. If it failed 'then the property doesn't exist. If Err.Number <> 0 Then 'Failed to get the existing property so create a new one. Call customPropSet.Add(PropertyValue, PropertyName) Else 'Change the value of the existing property. prop.Value = PropertyValue End If 'Update document Doc.Update End Sub
To test, just add some sheet metal parts to an assembly, add the code to VBA editor in the assembly, and then run macro named ProcessReferences.
Thank you for your time and attention. I look forward to the replies.
Kind regards,
Jerry
CAD Administrator
Using AutoCAD & Inventor 2025
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
JBerns
Community,
More debugging this morning led to a solution.
The UpdateCustomiProperty subroutine receives three parameters: a document, a string, and a variant.
In the ProcessReferences subroutine I had declared (DIM) the custom iProperty value as a string.
Although the string's value passed successfully to the UpdateCustomiProperty subroutine, the string value was not accepted during the PropertySet Add method.
Call customPropSet.Add(PropertyValue, PropertyName)   ' FAILS HERE
I changed the custom iProperty value declaration to a variant,
Dim strCustomerName As Variant
and then passed the variant to the UpdateCustomiProperty subroutine, it worked as expected.
I was certain you could pass any variable type to a variant, but this seems to cause a problem for the PropertySet Add method.
I would welcome any feedback on this issue.
Kind regards,
Jerry
CAD Administrator
Hey Jerry,
How's it going? I looked at your code and I believe I found the issue. I changed the PropertyValue back to a String datatype and changed the failed line to Set prop = customPropSet.Add(PropertyValue, PropertyName). Try that and hopefully it solves it on your end. I included the iLogic version as well if you needed it.
DanV
VBA version
Option Explicit
    'Initialize strings
        End If
        'Update document
        oRefDoc.Update
    Next
End Sub
Public Sub UpdateCustomiProperty(ByRef Doc As Document, ByRef PropertyName As String, ByRef PropertyValue As String) 'String
    Else
    End If
    'Update document
    Doc.Update
End Sub
iLogic Version
Sub Main()
    'Initialize strings
        End If
        'Update document
        oRefDoc.Update
    Next
End Sub
    Dim prop As Inventor.Property
    Try
	Catch
	Finally
	End Try
    Doc.Update
End Sub
JBerns
@Anonymous,
Thanks for looking at this. As I mentioned, a got this code from Brian Ekins.
Brian's UpdateCustomiProperty subroutine accepts the custom iProperty value as a variant so that you can send a string, date, number, or date.
Although your change will work since I am only passing strings, why can't the variable declared as a variant receive a value declared as a string, and then use it correctly in a Call statement or a Set statement?
Also thanks for the iLogic code. If the iLogic Editor had a better editor/debugger I would certainly be using it. MsgBox(es) get very tedious.
Jerry
CAD Administrator
Jerry,
Ok if you want to use a Variant instead of a specific datatype then you want to use ByVal instead of ByRef in your sub. With ByRef you are referencing the original argument and it's datatype. So that means that the datatype in the sub must match. With ByVal you are passing a copy of the variable. In doing so with a copy it will try convert to match the datatype in the sub. If there's no reason for it to be referencing the original variable then use ByVal. But if you do need to have it reference the original variable then make the Dim strCustomerName As Variant and keep ByRef in your sub. Hope that makes sense.
For iLogic, use Object instead of Variant.
DanV
Option Explicit
    'Initialize strings
        End If
        'Update document
        oRefDoc.Update
    Next
End Sub
Public Sub UpdateCustomiProperty(ByVal Doc As Document, ByVal PropertyName As String, ByVal PropertyValue As Variant) 'String
    Else
    End If
    'Update document
    Doc.Update
End Sub
JBerns
@Anonymous,
Thanks for the quick reply and explanation on ByRef versus ByVal. That does make sense.
On to the next phase of development. Have a great day.
Jerry
CAD Administrator
