Update iPart Author Table using iLogic
Message 1 of 9
Hello all,
I have a iPart that has a couple of different size members in it. I have iLogic that says when the Length grows, add another hole to the pattern. This code works perfectly on its own.
The problem is that the only way to update the member is to manually expand the iPart Table in the browser and click on each member to activate the member and then accept the change in the table (see attached image). After the change has been accepted I can generate my parts.
The code below will iterate through each part and generate my members.
I need a line of code that tells the table to update, accept the change and then generate the file. Does anyone know if this is possible?
SyntaxEditor Code Snippet
ThisDoc.Save
Dim oDoc As PartDocument = ThisDoc.Document
Dim oDef As PartComponentDefinition = oDoc.ComponentDefinition
Dim initRowIndex As Integer
Dim oFactory As iPartFactory = oDef.iPartFactory
Dim currow As Integer
currow = oFactory.DefaultRow.Index
' Iterate All Rows of iPart
Dim oRow As iPartTableRow
For Each oRow In oFactory.TableRows
	' Generate the member and file, (overwrites member file or creates new file)
	'oFactory.CreateMember(oRow)
	oFactory.DefaultRow = oRow
Next
iLogicVb.UpdateWhenDone = True
Replies (8)
Message 2 of 9
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Hoping that below iLogic code to update the value in iPart table. Make sure that proper column name should be updated in code.
oDoc = ThisApplication.ActiveDocument
oDef = oDoc.ComponentDefinition
oFactory = oDef.iPartFactory
    oRow.Item("LENGTH").Value = oRow.Item("LENGTH").Value + 1'need to update column name of Length
    oRow.Item("Hole_Number").Value = oRow.Item("Hole_Number").Value + 1 'need to update column name of hole pattern number
Next
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 3 of 9
chandra.shekar.g
Thank you for replying to my post. The code you supplied works for parameters that are actually in the model. But if I have a parameter in the iPart Table that is a User Parameter, this code doesnt work. Do you know of any work around?
Message 4 of 9
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Can you please provide sample iPart file to test? Please make sure that file is non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 5 of 9
Sure! Please see attached.
This example has other iLogic code in it that changes information in the table. But the information in the table only changes if you activate a member and accept the change. As previously mentioned, your code works for Model Parameters, but unfortunately not for User Parameters or Custom iProperties. The columns in the table that need to still change are: Description, ProNumber1 and Venture 7 1.
Please let me know if you have any questions
--Thanks!
Message 6 of 9
Looking further into the code you supplied, I dont think it actually works. I am supplying another sample part that has iLogic that controls Model Parameters and User Parameters. If you manually click each iPart member you have to accept the change made to the table from the iLogic.
Your code just makes each cell equal to itself. I need code that will make it equal to what the other iLogic rule tells it to be.
Please look through this sample part instead and let me know if you have questions.
Thanks!
Message 7 of 9
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Hoping that suggestions provided in the below blog article may help.
http://adndevblog.typepad.com/manufacturing/2013/02/manipulate-rows-and-columns-of-ipart-1.html
http://adndevblog.typepad.com/manufacturing/2013/03/manipulate-rows-and-columns-of-ipart-2.html
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 8 of 9
@chandra.shekar.g,
I have read these articles before. This is what makes me believe what I want to do is possible. These articles refer to making an iPart table using VBA. This is not my question. Please refer back to my actual question.
My table has already been created using iLogic code. The problem is that I have to manually click on each iPart member for the table to accept the change.
I have supplied a sample part above with all of the code that controls the iPart table.
Message 9 of 9
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Suppressing prompt while changing iPart member through UI (Manually) is not allowed through API. It is workflow of UI for iPart member change. Please log a wish list at idea station using below link.
https://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
