Update G_L property for all part files in assembly
I am trying to update value of G_L for every part in an assembly
illogic searches each part for parameter G_L and if the value = 914, then I want to update it to 950.
the code comes up with error 'cant find parameter G_L'
this is it:
any help?
Version:1.0 StartHTML:00000145 EndHTML:00003082 StartFragment:00000294 EndFragment:00003050 StartSelection:00000294 EndSelection:00000294SyntaxEditor Code Snippet
'Define the open document
Dim openDoc As Document
openDoc = ThisApplication.ActiveDocument
'Look at all of the files referenced in the open document
Dim partDoc As Document
For Each partDoc In openDoc.AllReferencedDocuments
     'look at only part files
     If partDoc.DocumentType = kPartDocumentObject Then
          Dim userParam As UserParameter
          For Each userParam In partDoc.ComponentDefinition.Parameters.UserParameters
                If Parameter("G_L") = 914 Then
					Parameter("G_L") = 950
           Next
     partDoc.Update
Next
iLogicVb.UpdateWhenDone = True
 Sandy
AlexFielder
I just re-read your OP and noticed that although you are looping through the userparameters in the correct fashion, the reason the code doesn't find and change the relevant parameter is because these lines:
are looking for the "G_L" parameter in the parent assembly.
You can get it to work like this:
			If userParam.Name = "G_L" Then
				If userParam.Expression = "914 mm" Then
					userParam.Expression = "950 mm"
				Else
					MessageBox.Show("User param is: " & userParam.Value)
'			If Parameter("G_L") = 914 Then
'				Parameter("G_L") = 950
'			End If
		Next
		partDoc.Update
Next
Obviously your units will likely be different, but I think you get the idea.
Would also like the thickness (G_T) to update depending on the (G_H) value....
Ive tried adding this into the code but unsuccessfully...!
Version:1.0 StartHTML:00000145 EndHTML:00004161 StartFragment:00000294 EndFragment:00004129 StartSelection:00000294 EndSelection:00000294SyntaxEditor Code Snippet
			If userParam.Name = "G_H" Then
				If userParam.Expression = "1165 mm" Then
					userParam.Expression = "1160.5 mm"
			If "G_H" = "1160.5 mm" Then
				If userParam.Expression = "G_T"
					userParam.Expression = "10 mm"
		Next
		partDoc.Update
Next
Sandy
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Try below iLogic code to update "G_T" value based on "G_H".
Dim update_GT As Boolean
update_GT = False
					update_GT = True
		Next
			If userParam.Name = "G_T" Then
				If update_GT = True Then
 					update_GT = False
		Next
		partDoc.Update
Next
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
