update drawing line colour based on part colour
brotherkennyh
Message 1 of 21
brotherkennyh
Is it possible to have the lines in an unshaded view follow the colour of the appearance of a part. I want to be able to see the part colour without having to have shaded views on.
Is this possible?
Failing that, is there a way to get the colour with iLogic to have the drawing line colours update automatically?
Cheers
Kenny
Accepted solutions (4)
Replies (20)
Message 21 of 21
coglesby7TUWS
I think I am using the same code as referenced above. I am not very good yet at coding so I wondered if anyone could help modify the code.
The issue I have is that all the lines will change to match the color of the model but the lines that it put on the "visible narrow" layer don't match.
It leaves those lines as white. For example a spline will show as white instead of matching the color of the model.
Sub Main
	' Get the active drawing document.
	Dim oDoc As DrawingDocument
	oDoc = ThisApplication.ActiveDocument
	Dim oSheets As Sheets
	oSheets = oDoc.Sheets
	Dim oSheet As Sheet
	'get current sheet so it can
	'be made active again later
	Dim oCurrentSheet As Sheet
	oCurrentSheet = oDoc.ActiveSheet
	Dim oViews As DrawingViews
	Dim oView As DrawingView
	' Iterate through the sheets
	For Each oSheet In oSheets
	'	activate the sheet
		oSheet.Activate
		'get the collection of view on the sheet
		oViews = oSheet.DrawingViews
		' Iterate through the views on the sheet
		For Each oView In oViews
			Dim docDesc As DocumentDescriptor
			docDesc = oView.ReferencedDocumentDescriptor
			' Verify that the drawing view is of an assembly.
			If docDesc.ReferencedDocumentType <> kAssemblyDocumentObject Then
				Continue For
			End If
			' Get the component definition for the assembly.
			Dim asmDef As AssemblyComponentDefinition
			asmDef = docDesc.ReferencedDocument.ComponentDefinition
			' Process the view, wrapping it in a transaction so the
			' each view can be undone with a single undo operation.
			Dim trans As Transaction
			trans = ThisApplication.TransactionManager.StartTransaction( _
									oDoc, "Change drawing view color")
			' Call the recursive function that does all the work.
			Call ProcessAssemblyColor(oView, asmDef.Occurrences)
			trans.End
		Next
		'update the sheet
		oSheet.Update
	Next
	'return to original sheet
	oCurrentSheet.Activate
End Sub
Private Sub ProcessAssemblyColor(drawView As DrawingView, _
                                 Occurrences As ComponentOccurrences)
   ' Iterate through the current collection of occurrences.
   Dim occ As ComponentOccurrence
   For Each occ In Occurrences
      ' Check to see if this occurrence is a part or assembly.
      If occ.DefinitionDocumentType = kPartDocumentObject Then
         ' ** It's a part so process the color.
         ' Get the render style of the occurrence.
         Dim color As RenderStyle
         Dim sourceType As StyleSourceTypeEnum
         color = occ.GetRenderStyle(sourceType)
         ' Get the TransientsObjects object to use later.
         Dim transObjs As TransientObjects
         transObjs = ThisApplication.TransientObjects
         ' Verify that a layer exists for this color.
         Dim layers As LayersEnumerator
         layers = drawView.Parent.Parent.StylesManager.layers
         oDoc = drawView.Parent.Parent
         On Error Resume Next
         Dim colorLayer As Layer
         colorLayer = layers.Item(color.Name)
         If Err.Number <> 0 Then
            On Error GoTo 0
            ' Get the diffuse color for the render style.
            Dim red As Byte
            Dim green As Byte
            Dim blue As Byte
            ' Create a color object that is the diffuse color.
            Call color.GetDiffuseColor(red, green, blue)
            Dim newColor As color
            newColor = transObjs.CreateColor(red, green, blue)
            ' Copy an arbitrary layer giving it the name
            ' of the render style.
            colorLayer = layers.Item(1).Copy(color.Name)
            ' the attributes of the layer to use the color,
            ' have a solid line type, and a specific width.
            colorLayer.Color = newColor
            colorLayer.LineType = kContinuousLineType
            colorLayer.LineWeight = 0.02
         End If
         On Error GoTo 0
         ' Get all of the curves associated with this occurrence.
         Dim drawcurves As DrawingCurvesEnumerator
         drawcurves = drawView.DrawingCurves(occ)
         If Err.Number = 0 Then
            On Error GoTo 0
            ' Create an empty collection.
            Dim objColl As ObjectCollection
            objColl = transObjs.CreateObjectCollection()
            ' Add the curve segments to the collection.
            Dim drawCurve As DrawingCurve
            For Each drawCurve In drawcurves
               Dim segment As DrawingCurveSegment
               For Each segment In drawCurve.Segments
                  objColl.Add (segment)
               Next
            Next
            ' Change the layer of all of the segments.
            Call drawView.Parent.ChangeLayer(objColl, colorLayer)
         End If
         On Error GoTo 0
      Else
         ' It's an assembly so process its contents.
         Call ProcessAssemblyColor(drawView, occ.SubOccurrences)
      End If
   Next
End Sub
