Update and Rebuild
Update and Rebuild
Update and Rebuild
What is the Update and Rebuild properties for DrawingDocuments supposed to
do? Why does both of these lines throw a error?
Dim oDDoc As DrawingDocument
Set oDDoc = ThisApplication.ActiveDocument
oDDoc.Update
oDDoc.Rebuild
Kent Keller
Member of the Autodesk Discussion Forum Moderator Program
http://www.MyMcad.com/KWiK/Mcad.htm
Kent,
I use this method (with no error) to update the model: ( the RaiseEvent is
there because its part of an Inventor Class Model I have built)..
Public Function UpdateModel() As Boolean
On Error (edited)
'Update the entire document
Set invDocument = invApp.ActiveDocument
invDocument.Update
'Update and Fit to window in one command
'invApp.ActiveView.Fit True
'Zoom All
With invApp.CommandManager
    .StartCommand kZoomAllCommand
    .StopActiveCommand
End With
'Raise Update event
RaiseEvent UpdateComplete
'Return success
UpdateModel = True
Exit Function
Hell:
    UpdateModel = False
End Function
Veign
www.veign.com
<> - Bigger, Better, Cleaner!
www.veign.com/download_application.html#Link200
Code Samples & Sample Projects
http://www.veign.com/information/application/info_app.html
NEW! - Quick Reference Guides
http://www.veign.com/company_store.html
Thanks for the reply, but is this for a drawing document? I have no
problems with the methods for parts and assemblies, but with idw files I do.
Ps. I find your error routine interesting coding style, but probably not
really appropriate for the Autodesk Server.
Kent Keller
"MajicMrln" wrote in message
news:440F89392AEE0B2C8ADF7F9B825193A4@in.WebX.maYIadrTaRb...
> Kent,
These two methods are on the Document object which means that all document
types inherit them. They are not currently supported on Drawing documents.
-Brian
"Kent Keller" wrote in message
news:7B6A31F812A5F96A2FF88CB41A363E40@in.WebX.maYIadrTaRb...
do.
> Kent Keller
> > Kent,
is
Thanks Brian... I didn't really think they fit in the Drawing Document
object... maybe a note in the help page for the DrawingDocument Object page
saying they aren't supported there would be helpful.
Kent Keller
"Brian Ekins (Autodesk)" wrote in message
news:FAF8365CE9B5A5F997B4C5FAE9AD60F3@in.WebX.maYIadrTaRb...
documents.
> -Brian
