How to programmatically constrain two axis?
I would like to constrain the X axis of a part to the X axis of the World.
I would really appreciate a short bit of code on how to do this, (assuming
that it should be short). Thanks!
Ed
Try this:
Public Sub ConstrainAxes()
' Get a reference to the assembly document.
Dim oAsmDoc As AssemblyDocument
Set oAsmDoc = ThisApplication.ActiveDocument
' Place the part into the assembly.
Dim oPartOcc As ComponentOccurrence
Set oPartOcc = oAsmDoc.ComponentDefinition.Occurrences.Add( _
"C:\Temp\Part1.ipt", _
ThisApplication.TransientGeometry.CreateMatrix)
' Get the X-axis work axis in the assembly.
Dim oAsmXAxis As WorkAxis
Set oAsmXAxis = oAsmDoc.ComponentDefinition.WorkAxes.Item(1)
' Get the X-axis work axis from the occurrent.
Dim oPartAxis As WorkAxis
Set oPartAxis = oPartOcc.Definition.WorkAxes.Item(1)
' The part work axis was obtained from the PartComponentDefinition
' associated with the part, so it is in the context of the part.
' We need it in the context of the assembly. This next step
' creates a WorkAxisProxy that represents that work axis in the
' context of the assembly.
Dim oPartAxisInAsm As WorkAxisProxy
Call oPartOcc.CreateGeometryProxy(oPartAxis, oPartAxisInAsm)
' Create a mate constraint between the axes.
Call oAsmDoc.ComponentDefinition.Constraints.AddMateConstraint( _
oAsmXAxis, oPartAxisInAsm, 0)
End Sub
-Brian
"Ed Thompson" wrote in message
news:0A89D27F4862226A274F7303105BB5A4@in.WebX.maYIadrTaRb...
> Ed
Brian,
I need to provide a component from a previously defined selection set. I'm
having trouble substituting my part for how the example defines the part
below. Hopefully, this only needs a couple of lines..
Ed
"Brian Ekins (Autodesk)" wrote in message
news:2C52EDB0E08D2C730936B873216A77FE@in.WebX.maYIadrTaRb...
> Try this:
> End Sub
> -Brian
World.
(assuming
> > Ed
