I have a simple part with a circular array of holes. The number of holes is defined by the multi-value list of a user parameter.
The part is inserted in an assembly which has a user parameter (HoleNumber) with the same multi-value list. A single line ilogic rule links the assembly to the part. An ilogic form in the assembly allows the hole pattern to be changed. Everything works as expected.
If I now copy the Master model state to create a Master1 model state the rule then fails with an unspecified error (see screen capture). I tried setting the active model state in the rule but the error persists.
Does anyone know what is causing the error?
I attach the part and assembly and screenshot.
Roger Mitchell
IV 2022.0.1
