Unspecified error when adding a model state to a part
rogmitch
rogmitch
I have a simple part with a circular array of holes.  The number of holes is defined by the multi-value list of a user parameter.
The part is inserted in an assembly which has a user parameter (HoleNumber) with the same multi-value list.  A single line ilogic rule links the assembly to the part.  An ilogic form in the assembly allows the hole pattern to be changed.  Everything works as expected.
If I now copy the Master model state to create a Master1 model state the rule then fails with an unspecified error (see screen capture).  I tried setting the active model state in the rule but the error persists.
Does anyone know what is causing the error?
I attach the part and assembly and screenshot.
Roger Mitchell
IV 2022.0.1
Curtis_Waguespack
Hi @rogmitch
It gets a little bit messier with model states, but if you change your rule to this (assuming the Model State name is correct), I think it'll work as expected.
I hope this helps.
Curtis
oOcc = Component.InventorComponent("Plate:1")
'activate it in the assembly
oOcc.ActiveModelState = "Model State1"
oMSFactory = oOcc.Definition.FactoryDocument
'activate it for edits in the part
oMSFactory.ComponentDefinition.ModelStates.Item("Model State1").Activate()
oMSFactory.ComponentDefinition.Parameters.ModelParameters.Item("d11").Value = HoleNumber
rogmitch
Hi Curtis,
Thank you - that did the trick.  I really appreciate the help as I would not have been able to sort that out myself as I have not found much relating to model state coding on-line.
Roger
Z0methink
I load two versions of the model:
1.with an error that occurs to me;
2.with my simpler solution.
jw_park29F53
Hello, I would like to ask you for help with Inventor iLogic.
I found your article helpful about utilizing variables in parts in Inventor model state.
I want to run a rule in a part.
oOcc = Component.InventorComponent("M4:1")
oOcc.ActiveModelState = "Non_Standard"
oMSFactory.ComponentDefinition.ModelStates.Item("Non_Standard").Activate()
oMSFactory.ComponentDefinition.iLogicVb.RunRule("M4:1","Excel to Parameter")
 I did the above, but I get an error.
