Unknown error when creating linear dimensions
chaillaudpaul
chaillaudpaul
Im currently working on putting linear dimensions on length and width for any part on a drawing my method seems correct but when it comes to actually adding the linear dimensions it crashes with "unspecified error" (0x80004005 (E_FAIL)),
The line causing that is:
            sheet.DrawingDimensions.GeneralDimensions.AddLinear(
                dimWidthPlacementPoint,
                geomIntentMinX,
                geomIntentMaxX,
                DimensionTypeEnum.kHorizontalDimensionType)
I checked and all parameters seem right yet i get this random error, any clues?
Ralf_Krieg
Hello
If we don't know how you create your intents, the placementpoint and so on, what do you expect we should say?
Does your code always fail on the same dimension or does it work once, then you delete it and it fails on the second try?
R. Krieg
RKW Solutions
www.rkw-solutions.com
