UnitsOfMeasure.GetTypeFromString Method Error
Genicee
Genicee
I don't know If I missing something, but UnitsOfMeasure.GetTypeFromString Method throws an exception when the Parameter Unit I enter is a "Text"
For Eample In a part of my Function to determine what kind of Unit I am working with I have a Case for "Text", but it seems to throw an error when the Part Parameter I enter Unit Type is a "Text"
Select Case oUOM.GetTypeFromString(Parameter.Units)
    Case 11346
       Return Parameter.Value
End Select
ekinsb
The GetTypeFromString function is designed to fail if the input string is not represented by one of the types in UnitTypesEnum.  However, Text and Boolean types are supported and should return the correct type and currently do not.  I've filed a change request so the issue can be addressed.  For the current time you'll need to special case and look specificially for Text and Boolean types.
Brian Ekins
Mod the Machine blog
Genicee
Thank you,
That is what I ended up doing. I was just wanted to check to make sure it wasn't a bug of some sort.
