Sheet Metal template giving Error '13' and Non-empty VBA warning
I'm trying to breath life into an old Sheet Metal template.
It starts with the Non-Empty VBA warning. A mere nuisance.
From there, "Run-time error '13': type mismatch
Debugging, here's my screen (attached). I don't know enough about VB to know where there's a problem.
Any help would be appreciated. I think the original file is several years old.
ekinsb
I don't see any obviously wrong.  Would it be possible for you to send me the part, or even a simplified version of the part that still demonstrates the problem?
One thing you should be aware of though is that automatic macros, which this is using, are no longer supported as of Inventor 2014.  Equivalent functionality will need to be written as an add-in.
Brian Ekins
Mod the Machine blog
This is simply a part template. We're using 2013 Pro. How would I find and delete the unwanted macros?
