Units of Measure
Units of Measure
NachoShaw
Advisor Advisor
Units of Measure
NachoShaw
Hey
I am using a routine that gets a range box size and the return value is in the default unit of CM. We use 2 types of formats (in. for USA and mm for Aus).
I have looked at trying to use the document Units of Measure but all it really does is return the suffix format.
how can I convert it using the UOM so that the return value matches the current format of the document i.e. inches or mm?
thanks
Nacho
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
YuhanZhang
Here is a sample VBA to show how to convert the length value(in centimeters as default) to the document length units:
Sub ConvertValueToDocUnits()
    ' say you have a double value(in centimeters)
    Dim dRangeBoxVal As Double
    dRangeBoxVal = 2.54
    Dim oUOM As UnitsOfMeasure
    Set oUOM = ThisApplication.ActiveDocument.UnitsOfMeasure
    Dim dResultVal As Double
    dResultVal = oUOM.ConvertUnits(dRangeBoxVal, kCentimeterLengthUnits, oUOM.LengthUnits)
    Debug.Print dResultVal & " " & oUOM.GetStringFromType(oUOM.LengthUnits)
End Sub
Hope it helps.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
