Changing a documents format.
NachoShaw
Advisor Advisor
NachoShaw
Hey
How can I programatically change a documents format from say mm to in or vice versa?
Nacho
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
YuhanZhang
Here is a sample VBA code to change the document length unit for part and assembly:
Sub ChangeDocLengthUnitToCM()
    Dim oDoc As Document
    Set oDoc = ThisApplication.ActiveDocument
    If oDoc.DocumentType = kPartDocumentObject Or oDoc.DocumentType = kAssemblyDocumentObject Then
        Dim oUOM As UnitsOfMeasure
        Set oUOM = oDoc.UnitsOfMeasure
        Debug.Print oUOM.LengthUnits
        oUOM.LengthUnits = kCentimeterLengthUnits
End Sub
Hope it helps.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
