Unique Entity ID
Unique Entity ID
Unique Entity ID
Hi All,
I need to import geometry from DWG files and do the following
  1. Identify the profile type from a lookup table and its orientation from its type
  2. Look for marked entities
  3. Extrude the profiles and assemble the extrusions based on their relative positions described in a table and align them relative to entities identified in step 2
What is the best way to mark the entities in DWG or else import them in to Inventor and manualy mark them to present it to a utility?
I need to access the marked entities by their ID to get their coordinates
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Hoping that assigning Attributsets to entity may be helpful. For more details on Attributesets, refer below blog link.
https://modthemachine.typepad.com/my_weblog/2009/07/introduction-to-attributes.html
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Thanks Chandra, that was spot on. It gives me more ways to uniqly mark and identify entities.
