Unhandled Exception error in iLogic since moving to 2018.
SharkDesign
Mentor Mentor
Message 1 of 18
SharkDesign
Since moving to 2018, some of my iLogic code no longer works. I don't know enough about it to troubleshoot it myself. Has anyone any idea why this is happening?
If I run the form and try to change the customer, I get an unhandled exception.
Please note this issue only happens when opening direct from the library, if I move to a non-library folder it works fine. Is this a change in 2018, or a bug?
Part attached
iLogic code is triggered by a form.
iLogic code:
Sub Main
ProjectFolder="\\FDSSVR1\Projects\Inventor\$PROJECT FILES\"
JN=iProperties.Value("Project", "Project")
Nm=myName
Nm=iProperties.Value("Summary", "Author")
Part=iProperties.Value("Summary", "Title")
targetFolder = getFolderByPrefix(JN, ProjectFolder)
If targetFolder = "" Then
    ' couldn't find directory - exit sub or panic and die here
MessageBox.Show("No job number entered","Error")
Else
If Not System.IO.Directory.Exists(targetFolder & "Angle") Then
    System.IO.Directory.CreateDirectory(targetFolder & "Angle")
InventorVb.DocumentUpdate()
  	ThisDoc.Document.SaveAs(targetFolder & "\"&"Angle" & "\" & JN & " "& Part &(".ipt"), True)
MessageBox.Show("Part created", "Angle create")
End Sub
Function getFolderByPrefix(prefix As String, base_folder As String) As String
    Dim folder As String
    Dim prefixLength As Integer
    ' get the length of your prefix (e.g. length of 1234 is 4)
    prefixLength = Len(4)
    ' set folder to dir of your base_folder
    folder = Dir(base_folder & "\*", vbDirectory)
    ' loop through every immediate child item in folder
    Do While folder <> ""
        ' check it's a folder, and that it's first prefixLength (4) characters match the prefix
        If GetAttr(base_folder & "\" & folder) And vbDirectory And prefix = Left(folder, prefixLength) Then
            ' return this full path
            getFolderByPrefix = base_folder & folder & "\"
            ' stop searching - i.e. this will only find the *first* directory that matches prefix
            Exit Function
        ' go on to next one
        folder = Dir
    Loop
    getFolderByPrefix = ""
End Function
Details:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Runtime.InteropServices.COMException (0x80004005): Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
   at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
   at Inventor.Property.set_Value(Object )
   at iLogic.UiBuilderConnect.iPropertyConnector.SetPropertyValue(String setName, String propertyName, Object value)
   at iLogic.UiBuilderConnect.InventorDocumentConnector.SetValues(IEnumerable`1 parameters, IEnumerable`1 iProperties, Boolean delayRules)
   at iLogic.UiBuilderConnect.InventorDocumentConnector.SetPropertyValue(iPropertyIdentifier id, Object value)
   at Autodesk.iLogic.UiBuilder.UiLayoutControl.SetPropertyValue(iPropertyControl controlSpec, Object value)
   at System.Windows.Forms.Control.OnValidated(EventArgs e)
   at DevExpress.XtraEditors.BaseEdit.OnValidated(EventArgs e)
   at DevExpress.XtraEditors.TextEdit.OnValidated(EventArgs e)
   at System.Windows.Forms.Control.PerformControlValidation(Boolean bulkValidation)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.6.1590.0 built by: NETFXREL2
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
WpfHost
    Assembly Version: 0.0.0.0
    Win32 Version: 22, 0, 11200, 0000
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/WpfHost.DLL
System
    CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
InvAIRLookContent
    Assembly Version: 22.0.11200.0
    Win32 Version: 22.0.11200.0000
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/InvAIRLookContent.DLL
System.Core
    CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
InvIPC
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/InvIPC.DLL
InvUIModelBrowser
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/InvUIModelBrowser.DLL
InvUIModelPropertyPanel
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/InvUIModelPropertyPanel.DLL
WpfAppPage
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/WpfAppPage.DLL
PresentationFramework
    CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
WindowsBase
    CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
PresentationCore
    CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
System.Xaml
    CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
InvAIRLookResources
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/InvAIRLookResources.DLL
FlowRibbon
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/FlowRibbon.DLL
AdWindows
    Assembly Version: 2016.11.4.0
    Win32 Version: 2016.11.4.0
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/AdWindows.DLL
WindowsFormsIntegration
    CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
System.Xml
    CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
InvRibbonUIResources
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/InvRibbonUIResources.DLL
System.Drawing
    CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
InvRibbonUIResources.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/en-US/InvRibbonUIResources.resources.DLL
WpfAppPage.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/en-US/WpfAppPage.resources.DLL
PresentationFramework.Aero
    CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
AdApplicationFrame
    Win32 Version: 2016.11.12.0
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/AdApplicationFrame.DLL
InvAIRLookContent.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/en-US/InvAIRLookContent.resources.DLL
InvAIRLookColorImages
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/InvAIRLookColorImages.DLL
System.Configuration
    CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
Microsoft.Expression.Interactions
    Assembly Version: 4.5.0.0
    Win32 Version: 3.0.40218.0
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/Microsoft.Expression.Interactions.DLL
    CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
PresentationFramework-SystemXml
    CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll
PresentationFramework-SystemCore
    CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemCore/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemCore.dll
PresentationFramework.Luna
    CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Luna/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Luna.dll
UIAutomationTypes
    CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll
InvTutorial
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/InvTutorial.DLL
ClrAddinLoader
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/ClrAddinLoader.DLL
GeneralTools
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/GeneralTools/GeneralTools.dll
Autodesk.Inventor.Interop
    Assembly Version: 15.0.0.0
    Win32 Version: 15.0.0.0
    CodeBase: file:///C:/windows/assembly/GAC_MSIL/Autodesk.Inventor.Interop/15.0.0.0__d84147f8b4276564/Autodesk.Inventor.Interop.dll
stdole
    Assembly Version: 7.0.3300.0
    Win32 Version: 7.00.9466
    CodeBase: file:///C:/windows/assembly/GAC/stdole/7.0.3300.0__b03f5f7f11d50a3a/stdole.dll
Microsoft.VisualBasic
    Assembly Version: 10.0.0.0
    Win32 Version: 14.6.1590.0 built by: NETFXREL2
    CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
CustomMarshalers
    CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_64/CustomMarshalers/v4.0_4.0.0.0__b03f5f7f11d50a3a/CustomMarshalers.dll
Autodesk.iLogic
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/Autodesk.iLogic.DLL
DevExpress.Data.v16.1
    Assembly Version: 16.1.5.0
    Win32 Version: 16.1.5.0
    CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/DevExpress.Data.v16.1/v4.0_16.1.5.0__b88d1754d700e49a/DevExpress.Data.v16.1.dll
Autodesk.iLogic.CommonUI
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/Autodesk.iLogic.CommonUI.DLL
Autodesk.iLogic.Interfaces
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/Autodesk.iLogic.Interfaces.DLL
    Assembly Version: 22.0.0.0
    Win32 Version: 22.0.0.0
    CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/Autodesk.Inventor.Interop/v4.0_22.0.0.0__d84147f8b4276564/Autodesk.Inventor.Interop.dll
Autodesk.iLogic.Core
    Assembly Version: 22.0.11292.0
    Win32 Version: 22.0.11292.0
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/Autodesk.iLogic.Core.DLL
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/Autodesk.iLogic.UiBuilder.DLL
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/Autodesk.iLogic.Common.DLL
Autodesk.iLogic.DesignCopy
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/Autodesk.iLogic.DesignCopy.DLL
CCAddIn
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/CCAddIn.DLL
EMA2018
    Assembly Version: 6.7.7.0
    Win32 Version: 6.7.7.0
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/EMA2018.DLL
Granta.Gateway.DotNetInterface
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/Granta.Gateway.DotNetInterface.DLL
ADICommon
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/ADICommon.DLL
InteractiveTutorial
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/interactivetutorial.DLL
AddinNETFramework
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/AddinNETFramework.DLL
ClicJsInfoCenter
    Win32 Version: 5.1.4.0
    CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/CLM/V5/MSVC14/ClicJsInfoCenter.dll
Autodesk.iLogic.UiBuilderCore
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/Autodesk.iLogic.UiBuilderCore.DLL
AppCmdServer
    Win32 Version: 1.0.16204.13207
    CodeBase: file:///C:/Program%20Files/3Dconnexion/3DxWare/3DxInventor64/AppCmdServer.dll
AdditiveMFG
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/additivemfg.DLL
Configurator360Addin
    Assembly Version: 22.0.10400.9000
    Win32 Version: 22.0.10400.9000
    CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/C360addin.bundle/Contents/x64/C360/Configurator360Addin.dll
Configurator360AddinBase
    CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/C360addin.bundle/Contents/x64/C360/Configurator360AddinBase.DLL
Autodesk.ETO.AssemblyConnectors
    Assembly Version: 12.0.0.0
    Win32 Version: 12.0.0
    CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/C360addin.bundle/Contents/x64/C360/Autodesk.ETO.AssemblyConnectors.DLL
Configurator360Addin.Connectors
    CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/C360addin.bundle/Contents/x64/C360/Configurator360Addin.Connectors.DLL
AnarkCoreInventorAddIn
    Assembly Version: 4.5.8.13192
    Win32 Version: 4.5.8.13192
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/AnarkCoreInventorAddIn.DLL
AssemblyBonusTools
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/assemblybonustools.DLL
AssemblyBonusToolsRes
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/en-US/AssemblyBonusToolsRes.dll
AceInvAddIn
    Assembly Version: 15.0.50.0
    Win32 Version: 15.0.50.0
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/InventorElectrical/AceInvAddIn.dll
    Assembly Version: 21.0.0.0
    Win32 Version: 21.0.0.0
    CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/Autodesk.Inventor.Interop/v4.0_21.0.0.0__d84147f8b4276564/Autodesk.Inventor.Interop.dll
AceCatalogBrowserCommonCtrl
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/InventorElectrical/AceCatalogBrowserCommonCtrl.DLL
AceDataStore
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/InventorElectrical/AceDataStore.DLL
System.Data
    CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
AceInvAddIn.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/InventorElectrical/en-US/AceInvAddIn.resources.DLL
InvUIModelBrowser.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/en-US/InvUIModelBrowser.resources.DLL
AdUIModel
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/AdUIModel.DLL
AdUIModel.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/en-US/AdUIModel.resources.DLL
PresentationFramework-SystemData
    CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemData/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemData.dll
System.Numerics
    CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
AceCatalogBrowserCommonCtrl.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/InventorElectrical/en-US/AceCatalogBrowserCommonCtrl.resources.DLL
AdUiPalettes
    Win32 Version: 21.0.49.0.0
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/AdUiPalettes.DLL
System.Web
    CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_64/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll
Microsoft.GeneratedCode
Autodesk.iLogic.Exec
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/Autodesk.iLogic.Exec.DLL
vj0jexsf
Autodesk.iLogic.Runtime
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/Autodesk.iLogic.Runtime.DLL
kh1yan4c
4dx3up4o
UIAutomationProvider
    CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
InvUIModelPropertyPanel.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/en-US/InvUIModelPropertyPanel.resources.DLL
Iop
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/Iop.DLL
TreeControlDotNET
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/TreeControlDotNET.DLL
DevExpress.XtraTreeList.v16.1
    CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/DevExpress.XtraTreeList.v16.1/v4.0_16.1.5.0__b88d1754d700e49a/DevExpress.XtraTreeList.v16.1.dll
DevExpress.XtraEditors.v16.1
    CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/DevExpress.XtraEditors.v16.1/v4.0_16.1.5.0__b88d1754d700e49a/DevExpress.XtraEditors.v16.1.dll
DevExpress.Utils.v16.1
    CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/DevExpress.Utils.v16.1/v4.0_16.1.5.0__b88d1754d700e49a/DevExpress.Utils.v16.1.dll
System.Data.Linq
    CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Data.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Data.Linq.dll
System.ComponentModel.DataAnnotations
    CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.ComponentModel.DataAnnotations/v4.0_4.0.0.0__31bf3856ad364e35/System.ComponentModel.DataAnnotations.dll
yacv3wj0
222r54mn
t2mbnzdq
jjw0kzuw
3cfdxpz1
ptmeksa5
eea3g2ls
oaegabxn
0d3mznkp
sesyu0cv
eh4ea2fo
5fsotutn
1bc2jevq
2wiep1um
InvTaskDialog
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/InvTaskDialog.DLL
2w111w4y
btvfster
uketl5p4
q3kc24ba
vxn4b40n
kbys0mbz
dyqdletg
jgc5lu5m
zcl3strj
a0bw15tw
3vo515vh
hpmgsbsc
MFCM140U
    Assembly Version: 14.0.24212.0
    Win32 Version: 14.0.24212.0 built by: VCTOOLSD14ULDR
    CodeBase: file:///C:/windows/system32/MFCM140U.dll
bednm2ca
hptnadyp
wwbo35ea
ifkoposb
1xhg13cf
05l1smdu
vjeaukj1
osqheq1x
LegacyPipeline
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/LegacyPipeline.DLL
CCCBL
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/CCCBL.DLL
CCServerProxies.Object
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/CCServerProxies.Object.DLL
CCServerProxies
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/CCServerProxies.DLL
RemoteContentProxies
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/RemoteContentProxies.DLL
DesktopServerProxies
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/DesktopServerProxies.DLL
Connectivity.Platform
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/Connectivity.Platform.DLL
System.Data.SQLite
    Assembly Version: 1.0.88.0
    Win32 Version: 1.0.88.0
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/System.Data.SQLite.DLL
System.Transactions
    CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_64/System.Transactions/v4.0_4.0.0.0__b77a5c561934e089/System.Transactions.dll
System.Web.Services
    CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Web.Services/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
System.EnterpriseServices
    CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_64/System.EnterpriseServices/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
CMAPI
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/CMAPI.DLL
Connectivity.Content
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/Connectivity.Content.DLL
ICSharpCode.SharpZipLib
    Assembly Version: 0.85.4.369
    Win32 Version: 0.85.4.369
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/ICSharpCode.SharpZipLib.DLL
0aowzfw2
i1b0eexl
v2bbzmni
mci15j4k
2ou4riiv
hq5l1y2c
25ae3ve2
o14iavzt
dddzm0bo
p50a2v4p
4tbpiexg
3edrp0xi
ebkbd14a
orqv3b4y
qxtrdmxd
sy14dsx2
lqjdfocb
t3y3bd5u
uwvnliil
5dllr5d2
xoojsykq
2vboqhny
cvd1v10x
DevExpress.XtraLayout.v16.1
    CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/DevExpress.XtraLayout.v16.1/v4.0_16.1.5.0__b88d1754d700e49a/DevExpress.XtraLayout.v16.1.dll
Anonymously Hosted DynamicMethods Assembly
    CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_64/mscorlib/v4.0_4.0.0.0__b77a5c561934e089/mscorlib.dll
Accessibility
    CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
UIAutomationClient
    CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationClient/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationClient.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
  Inventor Certified Professional
Replies (17)
Message 2 of 18
JaneFan
Hello James,
Is the files in library write protected?
Seems this is a similar question with this one: https://forums.autodesk.com/t5/inventor-customization/ilogic-error/td-p/7133836
In inventor 2018, writing in properties of write protected files are not allowed.
Jane Fan
Inventor/Fusion QA Engineer
Message 3 of 18
SharkDesign
OK, I see that this is new.
How can I fix my ilogic so I don't get this error anymore?
I have to do it this way because iparts are effectively broken as there is noway to tell them to save to a different folder automatically so they all get bunched up in the main inventor folder.
Message 4 of 18
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @jameswillo,
Sometimes, users will try to edit/modify Library files and saves automatically. Which affects original Inventor Library files.
So, In order to protect Inventor Library files, files are made it "Read-Only". This is introduced in Inventor 2018.
Due to this, exception error is thrown while accessing Library files.
Please feel free to contact if there is any doubt.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 5 of 18
SharkDesign
I understand that it's changed, what I want to know is how to change my code so that it still works?
Message 6 of 18
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @SharkDesign,
As you stated in the above, Please move all files to non - library folder.
No changes is required to code. As it is working for non - library folder.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 7 of 18
SharkDesign
I need it in the library it's a shared part and needs to be read only and in a central location.
Message 8 of 18
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @SharkDesign,
Can you please explain functionality of following iLogic code with example?
            Exit Function
        ' go on to next one
        folder = Dir
    Loop
End Function
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 9 of 18
SharkDesign
We only have one Inventor project file and all jobs are saved in a single folder separated by job numbers.
So you have:
Workspace > Our project folder > then a folder for each job/work order.
Each folder starts with a four digit job number but has random text after this including the customer name and a name of what the project is.
The code is matching the iProperty field 'project' (job number) to the first 4 digits of the folder so it knows where to save the file it creates.
Message 10 of 18
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @SharkDesign,
Please try the following iLogic code to find target folder using System.IO.
Imports System.IO
    Dim path As String()
path = Directory.GetDirectories(base_folder, prefix & "*") If path.Length = 0 Then Return ""
Else Return path(0) End If End Function
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 11 of 18
SharkDesign
That might work, but that is not why the error is occuring.
The issue is that the form is trying to write information to the iproperties and it can't because it is read only.
This is how it works:
Open form, type in the customer name, this writes to company iproperty
Type job number, writes to project and is used for save location
Name writes in title
Material sets material
The next 4 write to the parameters
When you hit create, it should then write those unsaved alterations to a new file at the location specified by the code you just queried.
All these writing operations now being blocked cos of the change in Inventor.
How can I change my code so that it works?
Message 12 of 18
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @SharkDesign,
For Testing purpose, save a file in Network location manually. There might be problem with network accessibility.
There is no much changes in code. I created a iLogic form and tested the same.
iLogic code works fine. Tested part is also attached with this post.
Sub Main()
	ProjectFolder="\\lion\test"
	Nm=myName
	Else
End Sub
    path = System.IO.Directory.GetDirectories(base_folder, prefix & "*")
		Return ""
    Else
		Return path(0)
End Function
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 13 of 18
SharkDesign
Thanks I will try this out sometime next week.
Message 14 of 18
SharkDesign
Sorry it's taken me so long to look at this.
Unfortunately it doesn't work and returns the same unhandled exception as before.
Message 15 of 18
CattabianiI
I didn't read the whole thread, but if your original problem related to write protection for library's files there's a solution since Inventor 2018.2
MjDeck wrote:
There is an option. It's available only in the recently released Inventor 2018.2 Update.
To enable it, set the Inventor.Application._LibraryDocumentModifiable property to true. Example:
ThisApplication._LibraryDocumentModifiable = True
Remember to set back the property to false once you did your changes, the property they added to workaround this problem is quite powerful and makes the files modifiable to the end user too.
Message 16 of 18
SharkDesign
Does this mean that whilst I am editing it, anybody else using the same project file would also be bale to modify files in the library?
Message 17 of 18
CattabianiI
I'm testing this thing but I don't think so, that property refers to your inventor application. So if you forget to set back to false that option you could edit your lib's files even through the UI and not only via API, but only you!
What I'm suggesting is to define something like this:
SyntaxEditor Code Snippet
Public Sub SetLibFileiProp(doc As Document, propSetName As String, name As String, value As String)
	Try
		doc.PropertySets.Item(propSetName).Item(name) = value
	Catch ex As Exception
		MsgBox(ex.ToString)
	Finally
		ThisApplication._LibraryDocumentModifiable = False
	End Try
End Sub
Message 18 of 18
RoyWickrama_RWEI
I have this problem since a week ago.
I got it solved with your posting (my rules were Read-Only).
Thanks.
