Message 1 of 18
Unhandled Exception error in iLogic since moving to 2018.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Since moving to 2018, some of my iLogic code no longer works. I don't know enough about it to troubleshoot it myself. Has anyone any idea why this is happening?
If I run the form and try to change the customer, I get an unhandled exception.
Please note this issue only happens when opening direct from the library, if I move to a non-library folder it works fine. Is this a change in 2018, or a bug?
Part attached
iLogic code is triggered by a form.
iLogic code:
Sub Main ProjectFolder="\\FDSSVR1\Projects\Inventor\$PROJECT FILES\" JN=iProperties.Value("Project", "Project") Nm=myName Nm=iProperties.Value("Summary", "Author") Part=iProperties.Value("Summary", "Title") targetFolder = getFolderByPrefix(JN, ProjectFolder) If targetFolder = "" Then ' couldn't find directory - exit sub or panic and die here MessageBox.Show("No job number entered","Error") Else If Not System.IO.Directory.Exists(targetFolder & "Angle") Then System.IO.Directory.CreateDirectory(targetFolder & "Angle") End If InventorVb.DocumentUpdate() ThisDoc.Document.SaveAs(targetFolder & "\"&"Angle" & "\" & JN & " "& Part &(".ipt"), True) MessageBox.Show("Part created", "Angle create") End If End Sub Function getFolderByPrefix(prefix As String, base_folder As String) As String Dim folder As String Dim prefixLength As Integer ' get the length of your prefix (e.g. length of 1234 is 4) prefixLength = Len(4) ' set folder to dir of your base_folder folder = Dir(base_folder & "\*", vbDirectory) ' loop through every immediate child item in folder Do While folder <> "" ' check it's a folder, and that it's first prefixLength (4) characters match the prefix If GetAttr(base_folder & "\" & folder) And vbDirectory And prefix = Left(folder, prefixLength) Then ' return this full path getFolderByPrefix = base_folder & folder & "\" ' stop searching - i.e. this will only find the *first* directory that matches prefix Exit Function End If ' go on to next one folder = Dir Loop getFolderByPrefix = "" End Function
Details:
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.Runtime.InteropServices.COMException (0x80004005): Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL)) at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData) at Inventor.Property.set_Value(Object ) at iLogic.UiBuilderConnect.iPropertyConnector.SetPropertyValue(String setName, String propertyName, Object value) at iLogic.UiBuilderConnect.InventorDocumentConnector.SetValues(IEnumerable`1 parameters, IEnumerable`1 iProperties, Boolean delayRules) at iLogic.UiBuilderConnect.InventorDocumentConnector.SetPropertyValue(iPropertyIdentifier id, Object value) at Autodesk.iLogic.UiBuilder.UiLayoutControl.SetPropertyValue(iPropertyControl controlSpec, Object value) at System.Windows.Forms.Control.OnValidated(EventArgs e) at DevExpress.XtraEditors.BaseEdit.OnValidated(EventArgs e) at DevExpress.XtraEditors.TextEdit.OnValidated(EventArgs e) at System.Windows.Forms.Control.PerformControlValidation(Boolean bulkValidation) ************** Loaded Assemblies ************** mscorlib Assembly Version: 4.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll ---------------------------------------- WpfHost Assembly Version: 0.0.0.0 Win32 Version: 22, 0, 11200, 0000 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/WpfHost.DLL ---------------------------------------- System Assembly Version: 4.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- InvAIRLookContent Assembly Version: 22.0.11200.0 Win32 Version: 22.0.11200.0000 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/InvAIRLookContent.DLL ---------------------------------------- System.Core Assembly Version: 4.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll ---------------------------------------- InvIPC Assembly Version: 22.0.11200.0 Win32 Version: 22.0.11200.0000 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/InvIPC.DLL ---------------------------------------- InvUIModelBrowser Assembly Version: 22.0.11200.0 Win32 Version: 22.0.11200.0000 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/InvUIModelBrowser.DLL ---------------------------------------- InvUIModelPropertyPanel Assembly Version: 22.0.11200.0 Win32 Version: 22.0.11200.0000 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/InvUIModelPropertyPanel.DLL ---------------------------------------- WpfAppPage Assembly Version: 22.0.11200.0 Win32 Version: 22.0.11200.0000 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/WpfAppPage.DLL ---------------------------------------- PresentationFramework Assembly Version: 4.0.0.0 Win32 Version: 4.6.1590.0 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll ---------------------------------------- WindowsBase Assembly Version: 4.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll ---------------------------------------- PresentationCore Assembly Version: 4.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll ---------------------------------------- System.Xaml Assembly Version: 4.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll ---------------------------------------- InvAIRLookResources Assembly Version: 22.0.11200.0 Win32 Version: 22.0.11200.0000 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/InvAIRLookResources.DLL ---------------------------------------- FlowRibbon Assembly Version: 22.0.11200.0 Win32 Version: 22.0.11200.0000 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/FlowRibbon.DLL ---------------------------------------- AdWindows Assembly Version: 2016.11.4.0 Win32 Version: 2016.11.4.0 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/AdWindows.DLL ---------------------------------------- WindowsFormsIntegration Assembly Version: 4.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll ---------------------------------------- System.Xml Assembly Version: 4.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- InvRibbonUIResources Assembly Version: 22.0.11200.0 Win32 Version: 22.0.11200.0000 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/InvRibbonUIResources.DLL ---------------------------------------- System.Drawing Assembly Version: 4.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- InvRibbonUIResources.resources Assembly Version: 22.0.11200.0 Win32 Version: 22.0.11200.0000 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/en-US/InvRibbonUIResources.resources.DLL ---------------------------------------- WpfAppPage.resources Assembly Version: 22.0.11200.0 Win32 Version: 22.0.11200.0000 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/en-US/WpfAppPage.resources.DLL ---------------------------------------- PresentationFramework.Aero Assembly Version: 4.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll ---------------------------------------- AdApplicationFrame Assembly Version: 0.0.0.0 Win32 Version: 2016.11.12.0 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/AdApplicationFrame.DLL ---------------------------------------- InvAIRLookContent.resources Assembly Version: 22.0.11200.0 Win32 Version: 22.0.11200.0000 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/en-US/InvAIRLookContent.resources.DLL ---------------------------------------- InvAIRLookColorImages Assembly Version: 22.0.11200.0 Win32 Version: 22.0.11200.0000 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/InvAIRLookColorImages.DLL ---------------------------------------- System.Configuration Assembly Version: 4.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- Microsoft.Expression.Interactions Assembly Version: 4.5.0.0 Win32 Version: 3.0.40218.0 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/Microsoft.Expression.Interactions.DLL ---------------------------------------- System.Windows.Forms Assembly Version: 4.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- PresentationFramework-SystemXml Assembly Version: 4.0.0.0 Win32 Version: 4.6.1590.0 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll ---------------------------------------- PresentationFramework-SystemCore Assembly Version: 4.0.0.0 Win32 Version: 4.6.1590.0 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemCore/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemCore.dll ---------------------------------------- PresentationFramework.Luna Assembly Version: 4.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Luna/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Luna.dll ---------------------------------------- UIAutomationTypes Assembly Version: 4.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll ---------------------------------------- InvTutorial Assembly Version: 22.0.11200.0 Win32 Version: 22.0.11200.0000 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/InvTutorial.DLL ---------------------------------------- ClrAddinLoader Assembly Version: 0.0.0.0 Win32 Version: 22, 0, 11200, 0000 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/ClrAddinLoader.DLL ---------------------------------------- GeneralTools Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/GeneralTools/GeneralTools.dll ---------------------------------------- Autodesk.Inventor.Interop Assembly Version: 15.0.0.0 Win32 Version: 15.0.0.0 CodeBase: file:///C:/windows/assembly/GAC_MSIL/Autodesk.Inventor.Interop/15.0.0.0__d84147f8b4276564/Autodesk.Inventor.Interop.dll ---------------------------------------- stdole Assembly Version: 7.0.3300.0 Win32 Version: 7.00.9466 CodeBase: file:///C:/windows/assembly/GAC/stdole/7.0.3300.0__b03f5f7f11d50a3a/stdole.dll ---------------------------------------- Microsoft.VisualBasic Assembly Version: 10.0.0.0 Win32 Version: 14.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll ---------------------------------------- CustomMarshalers Assembly Version: 4.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_64/CustomMarshalers/v4.0_4.0.0.0__b03f5f7f11d50a3a/CustomMarshalers.dll ---------------------------------------- Autodesk.iLogic Assembly Version: 22.0.11200.0 Win32 Version: 22.0.11200.0 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/Autodesk.iLogic.DLL ---------------------------------------- DevExpress.Data.v16.1 Assembly Version: 16.1.5.0 Win32 Version: 16.1.5.0 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/DevExpress.Data.v16.1/v4.0_16.1.5.0__b88d1754d700e49a/DevExpress.Data.v16.1.dll ---------------------------------------- Autodesk.iLogic.CommonUI Assembly Version: 22.0.11200.0 Win32 Version: 22.0.11200.0 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/Autodesk.iLogic.CommonUI.DLL ---------------------------------------- Autodesk.iLogic.Interfaces Assembly Version: 22.0.11200.0 Win32 Version: 22.0.11200.0 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/Autodesk.iLogic.Interfaces.DLL ---------------------------------------- Autodesk.Inventor.Interop Assembly Version: 22.0.0.0 Win32 Version: 22.0.0.0 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/Autodesk.Inventor.Interop/v4.0_22.0.0.0__d84147f8b4276564/Autodesk.Inventor.Interop.dll ---------------------------------------- Autodesk.iLogic.Core Assembly Version: 22.0.11292.0 Win32 Version: 22.0.11292.0 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/Autodesk.iLogic.Core.DLL ---------------------------------------- Autodesk.iLogic.UiBuilder Assembly Version: 22.0.11200.0 Win32 Version: 22.0.11200.0 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/Autodesk.iLogic.UiBuilder.DLL ---------------------------------------- Autodesk.iLogic.Common Assembly Version: 22.0.11200.0 Win32 Version: 22.0.11200.0 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/Autodesk.iLogic.Common.DLL ---------------------------------------- Autodesk.iLogic.DesignCopy Assembly Version: 22.0.11200.0 Win32 Version: 22.0.11200.0 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/Autodesk.iLogic.DesignCopy.DLL ---------------------------------------- CCAddIn Assembly Version: 0.0.0.0 Win32 Version: 22, 0, 11200, 0000 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/CCAddIn.DLL ---------------------------------------- EMA2018 Assembly Version: 6.7.7.0 Win32 Version: 6.7.7.0 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/EMA2018.DLL ---------------------------------------- Granta.Gateway.DotNetInterface Assembly Version: 6.7.7.0 Win32 Version: 6.7.7.0 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/Granta.Gateway.DotNetInterface.DLL ---------------------------------------- ADICommon Assembly Version: 6.7.7.0 Win32 Version: 6.7.7.0 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/ADICommon.DLL ---------------------------------------- InteractiveTutorial Assembly Version: 22.0.11200.0 Win32 Version: 22.0.11200.0000 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/interactivetutorial.DLL ---------------------------------------- AddinNETFramework Assembly Version: 22.0.11200.0 Win32 Version: 22.0.11200.0000 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/AddinNETFramework.DLL ---------------------------------------- ClicJsInfoCenter Assembly Version: 0.0.0.0 Win32 Version: 5.1.4.0 CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/CLM/V5/MSVC14/ClicJsInfoCenter.dll ---------------------------------------- Autodesk.iLogic.UiBuilderCore Assembly Version: 22.0.11200.0 Win32 Version: 22.0.11200.0 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/Autodesk.iLogic.UiBuilderCore.DLL ---------------------------------------- AppCmdServer Assembly Version: 1.0.0.0 Win32 Version: 1.0.16204.13207 CodeBase: file:///C:/Program%20Files/3Dconnexion/3DxWare/3DxInventor64/AppCmdServer.dll ---------------------------------------- AdditiveMFG Assembly Version: 22.0.11200.0 Win32 Version: 22.0.11200.0000 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/additivemfg.DLL ---------------------------------------- Configurator360Addin Assembly Version: 22.0.10400.9000 Win32 Version: 22.0.10400.9000 CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/C360addin.bundle/Contents/x64/C360/Configurator360Addin.dll ---------------------------------------- Configurator360AddinBase Assembly Version: 22.0.10400.9000 Win32 Version: 22.0.10400.9000 CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/C360addin.bundle/Contents/x64/C360/Configurator360AddinBase.DLL ---------------------------------------- Autodesk.ETO.AssemblyConnectors Assembly Version: 12.0.0.0 Win32 Version: 12.0.0 CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/C360addin.bundle/Contents/x64/C360/Autodesk.ETO.AssemblyConnectors.DLL ---------------------------------------- Configurator360Addin.Connectors Assembly Version: 22.0.10400.9000 Win32 Version: 22.0.10400.9000 CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/C360addin.bundle/Contents/x64/C360/Configurator360Addin.Connectors.DLL ---------------------------------------- AnarkCoreInventorAddIn Assembly Version: 4.5.8.13192 Win32 Version: 4.5.8.13192 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/AnarkCoreInventorAddIn.DLL ---------------------------------------- AssemblyBonusTools Assembly Version: 22.0.11200.0 Win32 Version: 22.0.11200.0 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/assemblybonustools.DLL ---------------------------------------- AssemblyBonusToolsRes Assembly Version: 22.0.11200.0 Win32 Version: 22.0.11200.0 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/en-US/AssemblyBonusToolsRes.dll ---------------------------------------- AceInvAddIn Assembly Version: 15.0.50.0 Win32 Version: 15.0.50.0 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/InventorElectrical/AceInvAddIn.dll ---------------------------------------- Autodesk.Inventor.Interop Assembly Version: 21.0.0.0 Win32 Version: 21.0.0.0 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/Autodesk.Inventor.Interop/v4.0_21.0.0.0__d84147f8b4276564/Autodesk.Inventor.Interop.dll ---------------------------------------- AceCatalogBrowserCommonCtrl Assembly Version: 15.0.50.0 Win32 Version: 15.0.50.0 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/InventorElectrical/AceCatalogBrowserCommonCtrl.DLL ---------------------------------------- AceDataStore Assembly Version: 15.0.50.0 Win32 Version: 15.0.50.0 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/InventorElectrical/AceDataStore.DLL ---------------------------------------- System.Data Assembly Version: 4.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll ---------------------------------------- AceInvAddIn.resources Assembly Version: 15.0.50.0 Win32 Version: 15.0.50.0 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/InventorElectrical/en-US/AceInvAddIn.resources.DLL ---------------------------------------- InvUIModelBrowser.resources Assembly Version: 22.0.11200.0 Win32 Version: 22.0.11200.0000 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/en-US/InvUIModelBrowser.resources.DLL ---------------------------------------- AdUIModel Assembly Version: 22.0.11200.0 Win32 Version: 22.0.11200.0000 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/AdUIModel.DLL ---------------------------------------- AdUIModel.resources Assembly Version: 22.0.11200.0 Win32 Version: 22.0.11200.0000 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/en-US/AdUIModel.resources.DLL ---------------------------------------- PresentationFramework-SystemData Assembly Version: 4.0.0.0 Win32 Version: 4.6.1590.0 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemData/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemData.dll ---------------------------------------- System.Numerics Assembly Version: 4.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll ---------------------------------------- AceCatalogBrowserCommonCtrl.resources Assembly Version: 15.0.50.0 Win32 Version: 15.0.50.0 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/InventorElectrical/en-US/AceCatalogBrowserCommonCtrl.resources.DLL ---------------------------------------- AdUiPalettes Assembly Version: 21.0.0.0 Win32 Version: 21.0.49.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/AdUiPalettes.DLL ---------------------------------------- System.Web Assembly Version: 4.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_64/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll ---------------------------------------- Microsoft.GeneratedCode Assembly Version: 1.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- Autodesk.iLogic.Exec Assembly Version: 22.0.11200.0 Win32 Version: 22.0.11200.0 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/Autodesk.iLogic.Exec.DLL ---------------------------------------- vj0jexsf Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- Autodesk.iLogic.Runtime Assembly Version: 22.0.11200.0 Win32 Version: 22.0.11200.0 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/Autodesk.iLogic.Runtime.DLL ---------------------------------------- kh1yan4c Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- 4dx3up4o Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- UIAutomationProvider Assembly Version: 4.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll ---------------------------------------- InvUIModelPropertyPanel.resources Assembly Version: 22.0.11200.0 Win32 Version: 22.0.11200.0000 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/en-US/InvUIModelPropertyPanel.resources.DLL ---------------------------------------- Iop Assembly Version: 0.0.0.0 Win32 Version: 22, 0, 11200, 0000 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/Iop.DLL ---------------------------------------- TreeControlDotNET Assembly Version: 22.0.11200.0 Win32 Version: 22.0.11200.0 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/TreeControlDotNET.DLL ---------------------------------------- DevExpress.XtraTreeList.v16.1 Assembly Version: 16.1.5.0 Win32 Version: 16.1.5.0 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/DevExpress.XtraTreeList.v16.1/v4.0_16.1.5.0__b88d1754d700e49a/DevExpress.XtraTreeList.v16.1.dll ---------------------------------------- DevExpress.XtraEditors.v16.1 Assembly Version: 16.1.5.0 Win32 Version: 16.1.5.0 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/DevExpress.XtraEditors.v16.1/v4.0_16.1.5.0__b88d1754d700e49a/DevExpress.XtraEditors.v16.1.dll ---------------------------------------- DevExpress.Utils.v16.1 Assembly Version: 16.1.5.0 Win32 Version: 16.1.5.0 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/DevExpress.Utils.v16.1/v4.0_16.1.5.0__b88d1754d700e49a/DevExpress.Utils.v16.1.dll ---------------------------------------- System.Data.Linq Assembly Version: 4.0.0.0 Win32 Version: 4.6.1590.0 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Data.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Data.Linq.dll ---------------------------------------- System.ComponentModel.DataAnnotations Assembly Version: 4.0.0.0 Win32 Version: 4.6.1590.0 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.ComponentModel.DataAnnotations/v4.0_4.0.0.0__31bf3856ad364e35/System.ComponentModel.DataAnnotations.dll ---------------------------------------- yacv3wj0 Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- 222r54mn Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- t2mbnzdq Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- jjw0kzuw Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- 3cfdxpz1 Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- ptmeksa5 Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- eea3g2ls Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- oaegabxn Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- 0d3mznkp Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- sesyu0cv Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- eh4ea2fo Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- 5fsotutn Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- 1bc2jevq Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- 2wiep1um Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- InvTaskDialog Assembly Version: 0.0.0.0 Win32 Version: 22, 0, 11200, 0000 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/InvTaskDialog.DLL ---------------------------------------- 2w111w4y Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- btvfster Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- uketl5p4 Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- q3kc24ba Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- vxn4b40n Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- kbys0mbz Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- dyqdletg Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- jgc5lu5m Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- zcl3strj Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- a0bw15tw Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- 3vo515vh Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- hpmgsbsc Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- MFCM140U Assembly Version: 14.0.24212.0 Win32 Version: 14.0.24212.0 built by: VCTOOLSD14ULDR CodeBase: file:///C:/windows/system32/MFCM140U.dll ---------------------------------------- bednm2ca Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- hptnadyp Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- wwbo35ea Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- ifkoposb Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- 1xhg13cf Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- 05l1smdu Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- vjeaukj1 Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- osqheq1x Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- LegacyPipeline Assembly Version: 22.0.11200.0 Win32 Version: 22.0.11200.0000 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/LegacyPipeline.DLL ---------------------------------------- CCCBL Assembly Version: 0.0.0.0 Win32 Version: 22, 0, 11200, 0000 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/CCCBL.DLL ---------------------------------------- CCServerProxies.Object Assembly Version: 22.0.11200.0 Win32 Version: 22.0.11200.0000 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/CCServerProxies.Object.DLL ---------------------------------------- CCServerProxies Assembly Version: 22.0.11200.0 Win32 Version: 22.0.11200.0000 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/CCServerProxies.DLL ---------------------------------------- RemoteContentProxies Assembly Version: 22.0.11200.0 Win32 Version: 22.0.11200.0000 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/RemoteContentProxies.DLL ---------------------------------------- DesktopServerProxies Assembly Version: 22.0.11200.0 Win32 Version: 22.0.11200.0000 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/DesktopServerProxies.DLL ---------------------------------------- Connectivity.Platform Assembly Version: 22.0.11200.0 Win32 Version: 22.0.11200.0000 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/Connectivity.Platform.DLL ---------------------------------------- System.Data.SQLite Assembly Version: 1.0.88.0 Win32 Version: 1.0.88.0 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/System.Data.SQLite.DLL ---------------------------------------- System.Transactions Assembly Version: 4.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_64/System.Transactions/v4.0_4.0.0.0__b77a5c561934e089/System.Transactions.dll ---------------------------------------- System.Web.Services Assembly Version: 4.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Web.Services/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll ---------------------------------------- System.EnterpriseServices Assembly Version: 4.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_64/System.EnterpriseServices/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll ---------------------------------------- CMAPI Assembly Version: 0.0.0.0 Win32 Version: 22, 0, 11200, 0000 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/CMAPI.DLL ---------------------------------------- Connectivity.Content Assembly Version: 22.0.11200.0 Win32 Version: 22.0.11200.0000 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/Connectivity.Content.DLL ---------------------------------------- ICSharpCode.SharpZipLib Assembly Version: 0.85.4.369 Win32 Version: 0.85.4.369 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/ICSharpCode.SharpZipLib.DLL ---------------------------------------- Microsoft.GeneratedCode Assembly Version: 1.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- 0aowzfw2 Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- i1b0eexl Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- v2bbzmni Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- mci15j4k Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- 2ou4riiv Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- hq5l1y2c Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- 25ae3ve2 Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- o14iavzt Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- dddzm0bo Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- p50a2v4p Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- 4tbpiexg Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- 3edrp0xi Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- ebkbd14a Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- orqv3b4y Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- qxtrdmxd Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- sy14dsx2 Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- lqjdfocb Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- t3y3bd5u Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- uwvnliil Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- 5dllr5d2 Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- xoojsykq Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- 2vboqhny Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- cvd1v10x Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- DevExpress.XtraLayout.v16.1 Assembly Version: 16.1.5.0 Win32 Version: 16.1.5.0 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/DevExpress.XtraLayout.v16.1/v4.0_16.1.5.0__b88d1754d700e49a/DevExpress.XtraLayout.v16.1.dll ---------------------------------------- Microsoft.GeneratedCode Assembly Version: 1.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- Microsoft.GeneratedCode Assembly Version: 1.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- Anonymously Hosted DynamicMethods Assembly Assembly Version: 0.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_64/mscorlib/v4.0_4.0.0.0__b77a5c561934e089/mscorlib.dll ---------------------------------------- Accessibility Assembly Version: 4.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll ---------------------------------------- Microsoft.GeneratedCode Assembly Version: 1.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- UIAutomationClient Assembly Version: 4.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationClient/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationClient.dll ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box.
