unground, relocate/offset reground
Darkforce_the_ilogic_guy
Advisor Advisor
it is possible to make an ilogic code that..
1. ask how you want it to move(X,Y,Z)
2. check if the componemt is ground
3 remove ground
4. move componemt
5. reground if componemt was grounded
6. do 2-5 on all componemt
I found this code but it only move one at the time and it does not offset location but set an location. and ground no matter want .. and it use select ... witch is offen very slow . I want to do it withont select an to all componemt on firstlevel. can anyone help with this  in ilogic
'check for selection
Dim compOcc As ComponentOccurrence
Try
  compOcc = ThisDoc.Document.SelectSet.Item(1)
Catch
  MessageBox.Show("Please select a component before running this rule.", "iLogic")
  Return
End Try
' remove constraints for the selected component
Dim oConstraint As AssemblyConstraint
For Each oConstraint In compOcc.Constraints
oConstraint.Delete
Next
Dim uom As UnitsOfMeasure = ThisDoc.Document.UnitsOfMeasure
Dim convFactor As Double = uom.ConvertUnits(1.0, uom.LengthUnits, UnitsTypeEnum.kDatabaseLengthUnits)
' Get the current transformation matrix from the occurrence.
Dim oTransform As Matrix = compOcc.Transformation
X = InputBox("Enter X", "Title", "")
Y = InputBox("Enter Y", "Title", "")
Z = InputBox("Enter Z", "Title", "")
' Move the occurrence ignoring any constraints.
oTransform.SetTranslation(ThisApplication.TransientGeometry.CreateVector(X*convFactor, Y*convFactor, Z*convFactor))
compOcc.SetTransformWithoutConstraints(oTransform)
' ground the component
compOcc.Grounded = True
JhoelForshav
Sorry @Darkforce_the_ilogic_guy
I read to fast... You want to move the occurrence from previous position. at first  I posted a code that just set a new position aswell. Thats why there's an empty post above...
This should do the trick!
Dim oAsm As AssemblyDocument = ThisDoc.Document
Dim oSelSet As SelectSet = oAsm.SelectSet
oSelSet.Clear
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
Dim oUM As UnitsOfMeasure = ThisDoc.Document.UnitsOfMeasure
For Each oComp As ComponentOccurrence In oAsm.ComponentDefinition.Occurrences
	oSelSet.Select(oComp)
	Dim xyz As String = InputBox("Move component X,Y,Z", "Move this component", "0,0,0")
	Dim oX As Double = oUM.ConvertUnits(CDbl(xyz.Split(",")(0)), oUM.LengthUnits, UnitsTypeEnum.kDatabaseLengthUnits)
	Dim oY As Double = oUM.ConvertUnits(CDbl(xyz.Split(",")(1)), oUM.LengthUnits, UnitsTypeEnum.kDatabaseLengthUnits)
	Dim oZ As Double = oUM.ConvertUnits(CDbl(xyz.Split(",")(2)), oUM.LengthUnits, UnitsTypeEnum.kDatabaseLengthUnits)
	If oX + oY + oZ <> 0
		Dim Grounded As Boolean = oComp.Grounded
		If Grounded = True Then oComp.Grounded = False
		Dim oVector As Vector = oTG.CreateVector(oX, oY, oZ)
		Dim oMatrix As Matrix = oComp.Transformation.Copy
		oVector.AddVector(oMatrix.Translation)
		oMatrix.SetTranslation(oVector, False)
		oComp.Transformation = oMatrix
		oComp.Grounded = Grounded
	End If
	oSelSet.Clear
	InventorVb.DocumentUpdate()
Next
JhoelForshav
And I see now that you only wanted to input X,Y,Z once. Not for each occurrence.
Final code😆
	Next
End If
JhoelForshav
I just realized... If you input for example (10, -10, 0) In this rule nothing will happen. I thought it was a shortcut to determine if any value <> 0 to put If oX + oY + oZ <> 0. Because the sum of the values can be zero even though all of them isn't 0 this could result in the code doing nothing when it should be moving the occurrences.
This is the way to go...
If oX <> 0 Or oY <> 0 Or oZ <> 0
	Next
End If
