Unable to set light vector with VB.net
- Mute
- Permalink
- Report
I have been building automations that save custom Attributes to DesignViewRepresentation objects so I can batch render with custom PerspectiveAngle and ActiveLightingStyle.Lights. I can change the Intensity of a light, but I have been unable to change the Direction vector successfully. It just doesn't update the values. Any ideas?
Attachment: The attached should run in an assembly. Clicking "no" should allow you to change lighting properties or FOV for the specific view. Then it will open another dialogue for some finer control. I have some debug info showing once you have gone through this process to save lighting. You will need two views with different lights to see it fail. Pardon my syntax, I am self-taught.
TLDR: Inventor light direction vectors don't want to change? Help!
Most relevant code: Start at line 25 (127 in attachment)
' RESTORE VIEW v1.2
Function RestoreView(oView As DesignViewRepresentation) As Boolean
Dim TransVals As New List(Of String)
Dim InvisVals As New List(Of String)
Try
For Each oAttributeSet As AttributeSet In oView.AttributeSets
If oAttributeSet.Name = "TransparentOccurrences"
For Each oAttribute As Attribute In oAttributeSet
If oAttribute.Name.Contains("Trans") Then TransVals.Add(oAttribute.Value)
If oAttribute.Name.Contains("Invis") Then InvisVals.Add(oAttribute.Value)
Next
Else If oAttributeSet.Name = "FieldOfView"
Try
If oAttributeSet.Item(1).Value = 0 Then oAttributeSet.Item(1).Value = .65
CurrentCamera.PerspectiveAngle = oAttributeSet.Item(1).Value
Catch
oAttributeSet.Delete
End Try
Else If oAttributeSet.Name = "ViewLighting"
'///////////// DEBUG //////////////
MsgBox("saved light 1 vector: " & oAttributeSet.Item(1).Value & " x " & oAttributeSet.Item(2).Value & " x " & oAttributeSet.Item(3).Value)
MsgBox("saved light 2 vector: " & oAttributeSet.Item(5).Value & " x " & oAttributeSet.Item(6).Value & " x " & oAttributeSet.Item(7).Value)
'attempt 1
oAssembly.ActiveLightingStyle.Lights.Item(1).Direction.X = oAttributeSet.Item(1).Value
oAssembly.ActiveLightingStyle.Lights.Item(1).Intensity = oAttributeSet.Item(4).Value
'attempt 2
oAssembly.ActiveLightingStyle.Lights.Item(2).Direction.PutVectorData({oAttributeSet.Item(5).Value, oAttributeSet.Item(6).Value, oAttributeSet.Item(7).Value})
oAssembly.ActiveLightingStyle.Lights.Item(2).Intensity = oAttributeSet.Item(8).Value
MsgBox("actual light 1 vector: " & oAssembly.ActiveLightingStyle.Lights.Item(1).Direction.X & " x " & oAssembly.ActiveLightingStyle.Lights.Item(1).Direction.Y & " x " & oAssembly.ActiveLightingStyle.Lights.Item(1).Direction.Z)
MsgBox("actual light 2 vector: " & oAssembly.ActiveLightingStyle.Lights.Item(2).Direction.X & " x " & oAssembly.ActiveLightingStyle.Lights.Item(2).Direction.Y & " x " & oAssembly.ActiveLightingStyle.Lights.Item(2).Direction.Z)
End If
Next
Dim oComponent As ComponentOccurrence
For Each oComponent In oAssembly.ComponentDefinition.Occurrences
If Not(oComponent.Suppressed)
If InvisVals.Contains(oComponent.Name) Then
oComponent.Transparent = False
oComponent.Visible = False
Else If TransVals.Contains(oComponent.Name) Then
oComponent.Transparent = True
oComponent.Visible = True
Else If IsHallPart(oComponent.Name) Then
Else
End If
End If
Next
'set camera location
CurrentCamera.ApplyWithoutTransition
oView.RestoreCamera()
Catch ' it is possible to lose views. The view is deleted, but still is counted in the count. Weird. This catches it.
Return False ' failed
End Try
Return True
End Function
