two Sections Views one name
Hello all,
I have problem with section view names.
I have two section views with same name (one view is on drawing, second is out of drawing).
On section are important just bolts, flanges and weldings. So I don´t have many section, just one and duplicate line with B (arrow). In one drawing I have 11 section B-B, (10 out of drawing, one in drawing) Also, I use rule for automatic section, detail etc..
I want connect the name from "main" section (which is in drawing to others.)
Can anybody help me with problem?
I´m not sure If I explained it well.. Thank you.
WCrihfield
Why do you name different section views the same name?
Why do you have 10 section view outside of the drawing and one inside the drawing?
What do you mean by 'connect' the 'main' section view name to all the others?
Wesley Crihfield
(Not an Autodesk Employee)
