Change length of a content center file with ilogic.
gma
Message 1 of 12
gma
I need some help to change a lenght on a content center file with an ilogic code.
I have two legs with a cross tube between, so i have a main leg...
This cross tube is the picture below and the length of this tube depends of the width of the main leg.
F.eks
The width of the leg assembly is 500mm, then my tube have to be 400mm...
Does anyoune know how it can be coded?
Vh
GMA
Replies (11)
Message 2 of 12
JhoelForshav
@gma
If you could provide some files or more information that would help.
I can't really give more of an answear than this with the information I have right now.
The length of a CC-member is often controlled by a parameter named "B_L",
A simple iLogic rule to change the length:
Parameter("I158251:1", "B_L") = 400
iLogicVb.UpdateWhenDone = True
Message 3 of 12
gma
It dos't work here.
I think you use a custom cc file.
I use a standard file...
Is it not possible to change the length of a standard file?
Message 4 of 12
JhoelForshav
You have to replace it then. A bit more complex but absolutely doable.
See this code. It identifies the family and row of the member and replaces it with a new standard member of that row with your B_L-value of choice 🙂
Dim oDoc As AssemblyDocument = ThisDoc.Document
Dim oDef As AssemblyComponentDefinition = oDoc.ComponentDefinition
Dim oCC As ContentCenter = ThisApplication.ContentCenter
Dim oCCmember As ComponentOccurrence = oDef.Occurrences.ItemByName("KCKR 25 x 2 - 100:1")
Dim propSet As PropertySet = oCCmember.Definition.Document.PropertySets.Item("{B9600981-DEE8-4547-8D7C-E525B3A1727A}")
' Get FamilyId property
Dim familyId As Inventor.Property = propSet.Item("FamilyId")
'Get Family
Dim oContentFamily As ContentFamily = oCC.GetContentObject("v3#" & familyId.Value & "#")
' Get MemberId property
Dim strMemberId As String = propSet("MemberId").Value
'Get Row
Dim oContentTableRow As ContentTableRow = oCC.GetContentObject("v3#" & familyId.Value & "#" & strMemberId)
'Replace member
Dim ee As MemberManagerErrorsEnum
'B_L value
Dim oNv As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
oNv.Add("B_L", 400)
Dim oNewMember As String = oContentFamily.CreateMember(oContentTableRow, ee, "Some error occured", , False, , oNv)
oCCmember.Replace(oNewMember, False)
Message 5 of 12
gma
Perfect, it's working...
Thank you very much...
Regards
Gøsta.
Message 6 of 12
denis.semeniuc
Good job, is it possible to add in the code the possibility of changing the diameter of pipe.
Thank you.
Message 7 of 12
A.Acheson
Here is a method to do it. You can change the criteria of row selection to whatever make sense. For Pipe ND and SN are straight forwarded, basically anything that is a key in your CC dialog.
Dim oCCmember As ComponentOccurrence = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, "Select a component to add to the folder, Press Esc when Complete")
Dim NDList As String() = {"2", "3", "4", "5", "6" }
Dim ND As String = InputListBox("Choose a ND", NDList, "2", Title := "Change Pipe ND", ListName := "PIPE ND")
If ND = Nothing Then Return
Dim PL As String = InputBox("Enter a Length in inches", "PL", "600")
'Get FamilyId property.
'Get Family.
'Get Current Row
Dim oCurrentTableRow As ContentTableRow = oCC.GetContentObject("v3#" & familyId.Value & "#" & strMemberId)
'Set the column criteria.
Dim ND_Col As ContentTableColumn = oContentFamily.TableColumns.Item("ND")
Dim Sch_Col As ContentTableColumn = oContentFamily.TableColumns.Item("SN")
'Get current schedule or have seperate list.
Dim CurrentSch As String = oCurrentTableRow.GetCellValue(Sch_Col)
'Get Row.
For Each oContentTableRow In oContentFamily.TableRows
	'Set the criteria for row selection
	If oContentTableRow.GetCellValue(ND_Col) = ND AndAlso oContentTableRow.GetCellValue(Sch_Col) = CurrentSch
		'Logger.Info(oContentTableRow.Index)
		'PL value.
		oNv.Add("PL", PL)
		'Create Member.
		oNewMember = oContentFamily.CreateMember(oContentTableRow, ee, "Some error occured", , False, , oNv)
		'Replace member.
Next
If  String.IsNullOrEmpty(oNewMember) Then
	MessageBox.Show("No matching row found", "Title")
oDoc.Update
Regards
Alan
Message 8 of 12
denis.semeniuc
It works very well. thank you. I have another problem: see photo. I have a plate where the diameter and thickness change. I tried to apply the same rule with adaptation and it does not work. can you help me plizz.
Message 9 of 12
A.Acheson
Fairly simple just change "ND" for "Diameter" and "SN" for "Thickness". You need to ensure the Column name used is the system name and not the display name. At least from what I can remember.
Regards
Alan
Message 10 of 12
denis.semeniuc
I changed the parameters
Message"no matching row found"
Dim ND As String = InputListBox("Choose a ND", NDList, "2", Title := "Change Dia", ListName := "Dia")
Dim PL As String = InputBox("Enter a Thk in inches", "THK", "3/16")
'Get Family.
'Get Current Row
Dim ND_Col As ContentTableColumn = oContentFamily.TableColumns.Item("diameter")
Dim Sch_Col As ContentTableColumn = oContentFamily.TableColumns.Item("thickness")
'Get current schedule Or have seperate list.
'Get Row.
		'PL value.
		oNv.Add("thickness", PL)
		'Create Member.
		'Replace member.
Next
oDoc.Update
Message 11 of 12
A.Acheson
Is there a custom length/thickness value required? If not this needs to be removed from member creation. Are the column labels correct to system and not display name as they are different. Spelled correctly with correct case etc?
Regards
Alan
Message 12 of 12
denis.semeniuc
Tahks
