Turn sketch circle to construction line using iLogic
lance.burrows
lance.burrows
Most of what I draw are circular parts with either circular or square bolt holes. To save time I've made a custom part template that has a sketch containing most of the features used, including both the circle & square bolt hole in their starting position as construction lines. Currently I right click on the circle/square and turn the construction line(s) off then make the circular pattern.
Can iLogic toggle specific construction line(s) in a sketch on & off? I've got the iLogic form working for sketch dimensions, but not this.
I've used iLogic dimensioning in drawings with Capture Current State where I can select specific lines, but I'm not seeing a similar feature for sketches.
I'm using Inventor 2023
Michael.Navara
Try to use something like this
Sub Main()
    'Planar sketch must be active
    Dim oSketch As PlanarSketch = ThisApplication.ActiveEditObject
    MakeCirclesAsConstruction(oSketch, True)
End Sub
Private Sub MakeCirclesAsConstruction(oSketch As PlanarSketch, construction As Boolean)
    For Each oCircle As SketchCircle In oSketch.SketchCircles
        If Not oCircle.Construction = construction Then oCircle.Construction = construction
    Next
End Sub
Curtis_Waguespack
Hi @lance.burrows
If you have multiple circles in a sketch you can use something like this initially just to determine where the circle is in the circles collection ( is it item 1, is it item 2, etc?)
Dim oDoc As PartDocument
oDoc = ThisDoc.Document
oSketch = oDoc.ComponentDefinition.Sketches.Item("Sketch1")
Dim sSet As SelectSet
sSet = oDoc.SelectSet
i = 1
	sSet.Select(oCircle)
	MsgBox("This is oSketch.SketchCircles.item(" & i & ")")
	sSet.Clear
	i = i+1
Next
Once you know the circle item number, you can just use something like this to toggle it.
oCirlce = ThisDoc.Document.ComponentDefinition.Sketches.Item("Sketch1").SketchCircles.Item(2)
oCirlce.Construction = Not oCirlce.Construction
I hope this helps.
Curtis
lance.burrows
@Curtis_Waguespack
This works perfect, thanks!
