- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Most of what I draw are circular parts with either circular or square bolt holes. To save time I've made a custom part template that has a sketch containing most of the features used, including both the circle & square bolt hole in their starting position as construction lines. Currently I right click on the circle/square and turn the construction line(s) off then make the circular pattern.
Can iLogic toggle specific construction line(s) in a sketch on & off? I've got the iLogic form working for sketch dimensions, but not this.
I've used iLogic dimensioning in drawings with Capture Current State where I can select specific lines, but I'm not seeing a similar feature for sketches.
I'm using Inventor 2023
