- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm trying to export as dxf from parts; however, my script includes the tangent lines when exported, which means there are 3 bend lines instead of one. I want to turn off the IV_TANGENT and IV_ROLL_TANGENT layers.
My code is below.
Sub ExportFlatPatternToDXF2()
Dim SETFilePath As String
SETFilePath = "path"
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
MsgBox "Please open an assembly document.", vbExclamation, "iLogic"
Exit Sub
End If
Dim oAsmDoc As AssemblyDocument
Set oAsmDoc = ThisApplication.ActiveDocument
Dim oRefDocs As DocumentsEnumerator
Set oRefDocs = oAsmDoc.AllReferencedDocuments
Dim oRefDoc As Document
For Each oRefDoc In oRefDocs
If oRefDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
Dim oSheetMetDoc As PartDocument
Set oSheetMetDoc = ThisApplication.Documents.Open(oRefDoc.FullFileName, True)
Dim oCompDef As SheetMetalComponentDefinition
Set oCompDef = oSheetMetDoc.ComponentDefinition
Dim oDef As FlatPattern
' If oCompDef.HasFlatPattern = False Then
' oCompDef.Unfold
' End If
Set oDef = oCompDef.FlatPattern
If oDef Is Nothing Then GoTo NextOcc
Dim sOut As String
sOut = "FLAT PATTERN DXF?AcadVersion=2018&OuterProfileLayer=IV_INTERIOR_PROFILES"
Dim sFname As String
sFname = SETFilePath & "\" & oSheetMetDoc.DisplayName & ".dxf"
Dim oDataIO As DataIO
Set oDataIO = oCompDef.DataIO
oDataIO.WriteDataToFile sOut, sFname
oCompDef.FlatPattern.ExitEdit
End If
NextOcc:
Next oRefDoc
MsgBox "Flat patterns exported to " & SETFilePath, vbInformation, "iLogic"
End Sub
