Tube & Pipe api
Tube & Pipe api
Tube & Pipe api
Hi i am trying to make a inventor VBA macro that will convert all the autoroutes to sketch (convert to sketch in rmb menu)
And uncheck the fitting if a routepoint is set as a fitting.
But i can not come deeper with VBA than getting the name of the Route where the autoroute and the routepoint is in.
in 2008 there was no API available. How about now? is it in inventor 2012 or higer?
If so can somebody give me a push in the correct direction(inventor 2012).
Thanks!
ekinsb
I'm sorry to tell you that Tube and Pipe has still not provided any API support. I'm not aware of a feasible workaround.
Brian Ekins
Mod the Machine blog
