TRYING TO UPDATE PARTS AND SAVE THEM TO VARIOUS DIRECTORIS THEN UPDATE THE ASSEMBLY TO NEW PART NAMES
bmc_dowell
bmc_dowell
'UPDATE AND SAVE TUBE
 Dim UPDATEPIPE As PartDocument = ThisApplication.Documents.Open(AUTOMATIONDIR & BASEFILE, False)
	UPDATEPIPE.ComponentDefinition.Parameters.Item("DIAMETER").Expression = DIAMETER
	UPDATEPIPE.ComponentDefinition.Parameters.Item("THICKNESS").Expression = THICKNESS
	UPDATEPIPE.ComponentDefinition.Parameters.Item("TUBELENGTH").Expression = TUBELENGTH
	UPDATEPIPE.ComponentDefinition.Material.Name = MATERIALLIST
	UPDATEPIPE.Update
	UPDATEPIPE.Update2
	UPDATEPIPE.SaveAs(TUBELOCATION, True)
	UPDATEPIPE.Save
	UPDATEPIPE.Close
If UPDATEFLANGE = 1 Then
Dim UPDATESFS As PartDocument = ThisApplication.Documents.Open(AUTOMATIONDIR & SFSFILE, False)
	UPDATESFS.ComponentDefinition.Parameters.Item("FLANGETHICK").Expression = FLANGETHICK
	UPDATESFS.ComponentDefinition.Parameters.Item("DIAMETER").Expression = DIAMETER
	UPDATESFS.ComponentDefinition.Parameters.Item("INNEROFFSET").Expression = INNEROFFSET
	UPDATESFS.ComponentDefinition.Parameters.Item("OUTEROFFSET").Expression = OUTEROFFSET
	UPDATESFS.ComponentDefinition.Parameters.Item("HOLEOFFSET").Expression = HOLEOFFSET
	UPDATESFS.ComponentDefinition.Parameters.Item("NUMOFHOLES").Expression = NUMOFHOLES
	UPDATESFS.ComponentDefinition.Parameters.Item("HOLEDIAMETER").Expression = HOLEDIAMETER
	UPDATESFS.ComponentDefinition.Parameters.Item("FLANGEANGLE").Expression = FLANGEANGLE
	UPDATESFS.ComponentDefinition.Material.Name = MATERIALLIST
	UPDATESFS.Update
	UPDATESFS.Update2
	UPDATESFS.SaveAs(SFSLOCATION,True)
	UPDATESFS.SaveAs(ASSEMBLYLOCATION & SFSNEWFILE,True)
	UPDATESFS.Save
	UPDATESFS.Close
'UPDATE AND SAVE SFA
If UPDATEANGLE = 1 Then
Dim UPDATESFA As PartDocument = ThisApplication.Documents.Open(AUTOMATIONDIR & SFAFILE, False)
	UPDATESFA.ComponentDefinition.Parameters.Item("LEGLENGTH").Expression = LEGLENGTH
	UPDATESFA.ComponentDefinition.Parameters.Item("LEGTHICKNESS").Expression = LEGTHICKNESS
	UPDATESFA.ComponentDefinition.Parameters.Item("TOECURVE").Expression = TOECURVE
	UPDATESFA.ComponentDefinition.Parameters.Item("HEELCURVE").Expression = HEELCURVE
	UPDATESFA.ComponentDefinition.Parameters.Item("ANGLEOFFSET").Expression = ANGLEOFFSET
	UPDATESFA.ComponentDefinition.Parameters.Item("DIAMETER").Expression = DIAMETER
	UPDATESFA.ComponentDefinition.Parameters.Item("ANGLERING").Expression = ANGLERING
	UPDATESFA.ComponentDefinition.Parameters.Item("HOLEDIAMETER").Expression = HOLEDIAMETER
	UPDATESFA.ComponentDefinition.Parameters.Item("HOLEOFFSET").Expression = HOLEOFFSET
	UPDATESFA.ComponentDefinition.Parameters.Item("NUMOFHOLES").Expression = NUMOFHOLES
	UPDATESFA.ComponentDefinition.Material.Name = MATERIALLIST
	UPDATESFA.Update
	UPDATESFA.Update2
	UPDATESFA.Save
	UPDATESFA.SaveAs(SFALOCATION, True)
	UPDATESFA.SaveAs(ASSEMBLYLOCATION & SFANEWFILE, True)
	UPDATESFA.Close
'UPDATE AND SAVE SFS
	UPDATESFS.Update
	UPDATESFS.Update2
	UPDATESFS.Save
	UPDATESFS.Close
'SAVEAS IAM
MessageBox.Show("SAVE IAM")
MessageBox.Show(AUTOMATIONDIR & ASSEMBLYFILE)
Dim UPDATEASSY As AssemblyDocument
	UPDATEASSY = ThisApplication.Documents.Open(AUTOMATIONDIR & ASSEMBLYFILE, False)
MessageBox.Show("FILE OPEN")
	UPDATEASSY.SaveAs(IAMFILEPATH, True)
	UPDATEASSY.Close
'UPDATE AND SAVE IAM
 MessageBox.Show("UPDATE AND SAVE IAM")
 MessageBox.Show(IAMFILEPATH)
Dim UPDATEASSY2 As AssemblyDocument = ThisApplication.Documents.Open(IAMFILEPATH, False)
	UPDATEASSY2.ComponentDefinition.Parameters.Item("FLANGEANGLE").Expression = FLANGEANGLE
	Dim ACD As AssemblyComponentDefinition = UPDATEASSY2.ComponentDefinition
	For i As Integer = 1 To ACD.Occurrences.Count
    	Dim NUMPARTS As ComponentOccurrence = ACD.Occurrences.Item(i)
		If Left(NUMPARTS.Name, 3) = "SFA"
			NUMPARTS.Replace(ASSEMBLYLOCATION & SFANEWFILE, False)
		Else If Left(NUMPARTS.Name, 3) = "SFS"
			NUMPARTS.Replace(ASSEMBLYLOCATION & SFSNEWFILE, False)
		Else If Left(NUMPARTS.Name, 3) = "FLG"
		Else
			NUMPARTS.Replace(TUBELOCATION, False)
	Next
	UPDATEASSY2.Update
	UPDATEASSY2.Update2
	UPDATEASSY2.Save
	UPDATEASSY2.Close
everything but the iam portion will work
then nothing works
I think it might have to do with autorun, but I am not sure how to turn it off
System.ArgumentException: The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.PartDocument.SaveAs(String FileName, Boolean SaveCopyAs)
at ThisRule.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
A.Acheson
Here is an update. Mostly focusing on replacing occurrences. Added try catches in case there is errors on replacing files and also "then" to if statements. I had to switch off the parameters sections to test. If it occurs again ensure you are offering valid fullfilenames.
	UPDATEPIPE.Update
	UPDATEPIPE.Update2
	UPDATEPIPE.Save
	UPDATEPIPE.Close
	UPDATESFS.Update
	UPDATESFS.Update2
	UPDATESFS.Save
	UPDATESFS.Close
	UPDATESFA.Update
	UPDATESFA.Update2
	UPDATESFA.Save
	UPDATESFA.Close
	UPDATESFS.Update
	UPDATESFS.Update2
	UPDATESFS.Save
	UPDATESFS.Close
'SAVEAS IAM
	UPDATEASSY.Close
		If Left(NUMPARTS.Name, 3) = "SFA" Then
			Try
			Catch
				MessageBox.Show("Error in replacing file : " & ASSEMBLYLOCATION & SFANEWFILE)
			End Try
		ElseIf Left(NUMPARTS.Name, 3) = "SFS" Then
			Try
			Catch
				MessageBox.Show("Error in replacing file : " & ASSEMBLYLOCATION & SFSNEWFILE)
			End Try
		ElseIf Left(NUMPARTS.Name, 3) = "FLG" Then
			Try
			Catch
			End Try
		Else
			Try
			Catch
				MessageBox.Show("Error in replacing occurrence in else statement")
			End Try
	Next
	UPDATEASSY2.Update
	UPDATEASSY2.Update2
	UPDATEASSY2.Save
	UPDATEASSY2.Close
Regards
Alan
