Reorganize drop down lists?
Preston_Reed
Preston_Reed
Hello, is there a way to reorganize drop down lists on forms?  I have a list of horse power ratings and default organization is alphabetic so 150HP comes before 70HP or 50HP for example.  Is there a way to reorganize these drop downs?  Id really like it to be in order of 10, 20, 30 ect.  It may not work for this exact scenario but its been making me think, any help would be much appreciated.
Sub main
	iPropPumpMotor
End Sub
'PartNumber
Sub iPropPumpMotor
	MultiValue.SetValueOptions(True, DefaultIndex := 0)
	If HP = "7.5 HP" Then
		Component.IsActive("PumpMotor P-Base 12 in:1") = True
		Component.IsActive("PumpMotor P-Base 16.5 in:1") = False
		'set list
		MultiValue.SetList("PartNumber", "HO7P2BLE")
		'set default value
		Parameter("PartNumber") = "HO7P2BLE"
			If PartNumber = "HO7P2BLE" Then
				iProperties.Value("PumpMotor P-Base 12 in:1", "Project", "Description") = "MOTOR, VHS - 7.5 HP, 1765 RPM, 230-460/3/60"
				iProperties.Value("PumpMotor P-Base 12 in:1", "Project", "Part Number") = "HO7P2BLE"
	ElseIf HP = "10 HP" Then
		'set list
		MultiValue.SetList("PartNumber", "HO10E2BLE", "HT10P2BLE", "PHO10P2BLE")
		'set default value
		Parameter("PartNumber") = "HO10E2BLE"
			If PartNumber = "HO10E2BLE" Then
				iProperties.Value("PumpMotor P-Base 12 in:1", "Project", "Description") = "MOTOR, VHS - 10 HP, 1800 RPM, 230-460/3/60"
				iProperties.Value("PumpMotor P-Base 12 in:1", "Project", "Part Number") = "HO10E2BLE"
			ElseIf PartNumber = "HT10P2BLE" Then
				iProperties.Value("PumpMotor P-Base 12 in:1", "Project", "Description") = "PUMP MOTOR, 10 HP - 1800 RPM, TEFC, 230/460"
				iProperties.Value("PumpMotor P-Base 12 in:1", "Project", "Part Number") = "HT10P2BLE"
			ElseIf PartNumber = "PHO10P2BLE" Then
				iProperties.Value("PumpMotor P-Base 12 in:1", "Project", "Part Number") = "PHO10P2BLE"
	ElseIf HP = "15 HP" Then
		'set list
		MultiValue.SetList("PartNumber", "HO15S2BLE" , "HO15S2BLF" , "HO15V2BLE")
		'set default value
		Parameter("PartNumber") = "HO15S2BLE"
			If PartNumber = "HO15S2BLE" Then
				iProperties.Value("PumpMotor P-Base 12 in:1", "Project", "Description") = "MOTOR, VHS - 15 HP, 1800 RPM, 230-460/3/60"
				iProperties.Value("PumpMotor P-Base 12 in:1", "Project", "Part Number") = "HO15S2BLE"
			ElseIf PartNumber = "HO15S2BLF" Then
				iProperties.Value("PumpMotor P-Base 12 in:1", "Project", "Part Number") = "HO15S2BLF"
			ElseIf PartNumber = "HO15V2BLE" Then
				iProperties.Value("PumpMotor P-Base 12 in:1", "Project", "Description") = "PUMP MOTOR, 15 HP - 1800 RPM, Wp1, VHS"
				iProperties.Value("PumpMotor P-Base 12 in:1", "Project", "Part Number") = "HO15V2BLE"
	ElseIf HP = "20 HP" Then
		'set list
		MultiValue.SetList("PartNumber", "HO20P2BLF", "HO20P3BLG", "HO20V2BLF")
		'set default value
		Parameter("PartNumber") = "HO20P2BLF"
			If PartNumber = "HO20P2BLF" Then
				iProperties.Value("PumpMotor P-Base 12 in:1", "Project", "Description") = "PUMP MOTOR, 20HP - 1775 RPM, 230/460VAC"
				iProperties.Value("PumpMotor P-Base 12 in:1", "Project", "Part Number") = "HO20P2BLF"
			ElseIf PartNumber = "HO20P3BLG" Then
				iProperties.Value("PumpMotor P-Base 12 in:1", "Project", "Description") = "PUMP MOTOR, 20HP - 1175 RPM, 230/460VAC"
				iProperties.Value("PumpMotor P-Base 12 in:1", "Project", "Part Number") = "HO20P3BLG"
			ElseIf PartNumber = "HO20V2BLF" Then
				iProperties.Value("PumpMotor P-Base 12 in:1", "Project", "Description") = "PUMP MOTOR, 20 HP - 1800 RPM, Wp1, VHS"
				iProperties.Value("PumpMotor P-Base 12 in:1", "Project", "Part Number") = "HO20V2BLF"
	ElseIf HP = "25 HP" Then
		'set list
		MultiValue.SetList("PartNumber", "PHO25P2BLF" , "HO25P2BLG" , "HO25S1BLF" , "HO25S2BLF" , "HO25V2BLF" , "HO25V2BLG" , "HO25V2GLE")
		'set default value
		Parameter("PartNumber") = "PHO25P2BLF"
				iProperties.Value("PumpMotor P-Base 12 in:1", "Project", "Description") = "PUMP MOTOR, 25HP, WP1, PE, 1800, 230/460"
				iProperties.Value("PumpMotor P-Base 12 in:1", "Project", "Part Number") = "PHO25P2BLF"
				iProperties.Value("PumpMotor P-Base 12 in:1", "Project", "Description") = "PUMP MOTOR, 25 HP - 1800 RPM, Wp1, VHS"
				iProperties.Value("PumpMotor P-Base 12 in:1", "Project", "Part Number") = "HO25P2BLG"
			ElseIf PartNumber = "HO25S1BLF" Then
				iProperties.Value("PumpMotor P-Base 12 in:1", "Project", "Description") = "PUMP MOTOR, 25 HP - 3600 RPM, Wp1, VHS"
				iProperties.Value("PumpMotor P-Base 12 in:1", "Project", "Part Number") = "HO25S1BLF"
			ElseIf PartNumber = "HO25S2BLF" Then
				iProperties.Value("PumpMotor P-Base 12 in:1", "Project", "Part Number") = "HO25S2BLF"
			ElseIf PartNumber = "HO25V2BLF" Then
				iProperties.Value("PumpMotor P-Base 12 in:1", "Project", "Part Number") = "HO25V2BLF"
			ElseIf PartNumber = "HO25V2BLG" Then
				iProperties.Value("PumpMotor P-Base 12 in:1", "Project", "Description") = "Missing"
				iProperties.Value("PumpMotor P-Base 12 in:1", "Project", "Part Number") = "HO25V2BLG"
			ElseIf PartNumber = "HO25V2GLE" Then
				iProperties.Value("PumpMotor P-Base 12 in:1", "Project", "Description") = "PUMP MOTOR, 25 HP - 1800 RPM, Wp1, VHS, 575V"
				iProperties.Value("PumpMotor P-Base 12 in:1", "Project", "Part Number") = "HO25V2GLE"
	ElseIf HP = "30 HP" Then
		'set list
		MultiValue.SetList("PartNumber", "PHO30P2BLF" , "PHO30P2BLG" , "HO30P3BLG" , "HO30S2BLF" , "PHO30V2BLF")
		'set default value
		Parameter("PartNumber") = "PHO30P2BLF"
			If PartNumber = "PHO30P2BLF" Then
				iProperties.Value("PumpMotor P-Base 12 in:1", "Project", "Description") = "MOTOR, VHS - 30 HP, 1800 RPM, 230-460/3/60"
				iProperties.Value("PumpMotor P-Base 12 in:1", "Project", "Part Number") = "PHO30P2BLF"
			ElseIf PartNumber = "PHO30P2BLG" Then
				iProperties.Value("PumpMotor P-Base 12 in:1", "Project", "Description") = "PUMP MOTOR, 30HP - 1775 RPM, 460VAC"
				iProperties.Value("PumpMotor P-Base 12 in:1", "Project", "Part Number") = "PHO30P2BLG"
			ElseIf PartNumber = "HO30P3BLG" Then
				iProperties.Value("PumpMotor P-Base 12 in:1", "Project", "Description") = "PUMP MOTOR, 30HP - 1785 RPM, 460VAC"
				iProperties.Value("PumpMotor P-Base 12 in:1", "Project", "Part Number") = "HO30P3BLG"
			ElseIf PartNumber = "HO30S2BLF" Then
				iProperties.Value("PumpMotor P-Base 12 in:1", "Project", "Description") = "PUMP MOTOR, 30HP - 1770 RPM, 460VAC"
				iProperties.Value("PumpMotor P-Base 12 in:1", "Project", "Part Number") = "HO30S2BLF"
			ElseIf PartNumber = "PHO30V2BLF" Then
				iProperties.Value("PumpMotor P-Base 12 in:1", "Project", "Description") = "PUMP MOTOR, BF39 - 30HP, 1770 RPM, 460VAC"
				iProperties.Value("PumpMotor P-Base 12 in:1", "Project", "Part Number") = "PHO30V2BLF"
	ElseIf HP = "40 HP" Then
		Component.IsActive("PumpMotor P-Base 12 in:1") = False
		Component.IsActive("PumpMotor P-Base 16.5 in:1") = True
		'set list
		MultiValue.SetList("PartNumber", "PHO40P2BLG" , "HO40V2BLF")
		'set default value
		Parameter("PartNumber") = "PHO40P2BLG"
			If PartNumber = "PHO40P2BLG" Then
				iProperties.Value("PumpMotor P-Base 16.5 in:1", "Project", "Description") = "MOTOR, VHS - 40HP, 1780 RPM, 230/460VAC"
				iProperties.Value("PumpMotor P-Base 16.5 in:1", "Project", "Part Number") = "PHO40P2BLG"
			ElseIf PartNumber = "HO40V2BLF" Then
				iProperties.Value("PumpMotor P-Base 16.5 in:1", "Project", "Description") = "MOTOR, 40HP, 1800 RPM, 230/460VAC"
				iProperties.Value("PumpMotor P-Base 16.5 in:1", "Project", "Part Number") = "HO40V2BLF"
	ElseIf HP = "50 HP" Then
		'set list
		MultiValue.SetList("PartNumber", "PHO50P2BLG" , "PHO50P2BLGXYL" , "HO50S2BLG" , "PHO50V2BLF" , "HO50V2BLG" , "HO50V2GLG")
		'set default value
		Parameter("PartNumber") = "PHO50P2BLG"
			If PartNumber = "PHO50P2BLG" Then
				iProperties.Value("PumpMotor P-Base 16.5 in:1", "Project", "Description") = "MTR, VHS - 50HP, US, PREM, 1775 RPM, 230/460VAC"
				iProperties.Value("PumpMotor P-Base 16.5 in:1", "Project", "Part Number") = "PHO50P2BLG"
			ElseIf PartNumber = "PHO50P2BLGXYL" Then
				iProperties.Value("PumpMotor P-Base 16.5 in:1", "Project", "Description") = "MTR, VHS - 50HP, US, PE, 1800R"
				iProperties.Value("PumpMotor P-Base 16.5 in:1", "Project", "Part Number") = "PHO50P2BLGXYL"
			ElseIf PartNumber = "HO50S2BLG" Then
				iProperties.Value("PumpMotor P-Base 16.5 in:1", "Project", "Description") = "PUMP MOTOR, 50HP, 1800 RPM, 230/460VAC"
				iProperties.Value("PumpMotor P-Base 16.5 in:1", "Project", "Part Number") = "HO50S2BLG"
			ElseIf PartNumber = "PHO50V2BLF" Then
				iProperties.Value("PumpMotor P-Base 16.5 in:1", "Project", "Part Number") = "PHO50V2BLF"
			ElseIf PartNumber = "HO50V2BLG" Then
				iProperties.Value("PumpMotor P-Base 16.5 in:1", "Project", "Part Number") = "HO50V2BLG"
			ElseIf PartNumber = "HO50V2GLG" Then
				iProperties.Value("PumpMotor P-Base 16.5 in:1", "Project", "Description") = "PUMP MOTOR, 50HP, 1800 RPM, 575V/3/60"
				iProperties.Value("PumpMotor P-Base 16.5 in:1", "Project", "Part Number") = "HO50V2GLG"
	ElseIf HP = "60 HP" Then
		'set list
		MultiValue.SetList("PartNumber", "PHO60P2BLG", "HO60S2BLG", "PHO60V2GLG", "PHO60V2SLG")
		'set default value
		Parameter("PartNumber") = "PHO60P2BLG"
			If PartNumber = "PHO60P2BLG" Then
				iProperties.Value("PumpMotor P-Base 16.5 in:1", "Project", "Description") = "MOTOR, 60HP,  PREM EFF, VHS, 1800RPM, 460/3/60, NRR, 1-3/16 BX"
				iProperties.Value("PumpMotor P-Base 16.5 in:1", "Project", "Part Number") = "PHO60P2BLG"
			ElseIf PartNumber = "HO60S2BLG" Then
				iProperties.Value("PumpMotor P-Base 16.5 in:1", "Project", "Description") = "PUMP MOTOR, 60HP, 1800 RPM, 230/460VAC"
				iProperties.Value("PumpMotor P-Base 16.5 in:1", "Project", "Part Number") = "HO60S2BLG"
			ElseIf PartNumber = "PHO60V2GLG" Then
				iProperties.Value("PumpMotor P-Base 16.5 in:1", "Project", "Description") = "PUMP MOTOR, 60HP, 1800 RPM, 575V/3/60"
				iProperties.Value("PumpMotor P-Base 16.5 in:1", "Project", "Part Number") = "PHO60V2GLG"
			ElseIf PartNumber = "PHO60V2SLG" Then
				iProperties.Value("PumpMotor P-Base 16.5 in:1", "Project", "Part Number") = "PHO60V2SLG"
	ElseIf HP = "75 HP" Then
		'set list
		MultiValue.SetList("PartNumber", "HO75E2G", "PHO75P2BLGXYL", "HO75S2BLG", "HO75V2GLG", "HO75V2SLG")
		'set default value
		Parameter("PartNumber") = "HO75E2G"
			If PartNumber = "HO75E2G" Then
				iProperties.Value("PumpMotor P-Base 16.5 in:1", "Project", "Description") = "VERTICAL MOTOR - 75 HP, 1775 RPM"
				iProperties.Value("PumpMotor P-Base 16.5 in:1", "Project", "Part Number") = "HO75E2G"
			ElseIf PartNumber = "PHO75P2BLGXYL" Then
				iProperties.Value("PumpMotor P-Base 16.5 in:1", "Project", "Description") = "MTR, VHS - 75HP, US, PE, 1800RPM, 460/3/60, NRR, 1.1875IN"
				iProperties.Value("PumpMotor P-Base 16.5 in:1", "Project", "Part Number") = "PHO75P2BLGXYL"
			ElseIf PartNumber = "HO75S2BLG" Then
				iProperties.Value("PumpMotor P-Base 16.5 in:1", "Project", "Description") = "PUMP MOTOR, 75HP - 1800RPM, 460/3/60"
				iProperties.Value("PumpMotor P-Base 16.5 in:1", "Project", "Part Number") = "HO75S2BLG"
			ElseIf PartNumber = "HO75V2GLG" Then
				iProperties.Value("PumpMotor P-Base 16.5 in:1", "Project", "Description") = "PUMP MOTOR, 75HP - 575/3/60, 1800RPM"
				iProperties.Value("PumpMotor P-Base 16.5 in:1", "Project", "Part Number") = "HO75V2GLG"
			ElseIf PartNumber = "HO75V2SLG" Then
				iProperties.Value("PumpMotor P-Base 16.5 in:1", "Project", "Description") = "PUMP MOTOR, 75HP - 460/3/60, 1800RPM"
				iProperties.Value("PumpMotor P-Base 16.5 in:1", "Project", "Part Number") = "HO75V2SLG"
	ElseIf HP = "100 HP" Then
		'set list
		MultiValue.SetList("PartNumber", "HO100P2BLG", "PHO100P2SLG", "HO100S2BLG", "HO100V2SLG")
		'set default value
		Parameter("PartNumber") = "HO100P2BLG"
			If PartNumber = "HO100P2BLG" Then
				iProperties.Value("PumpMotor P-Base 16.5 in:1", "Project", "Description") = "MOTOR, 100HP, 1800RPM, 404T, 230/460V, TEF"
				iProperties.Value("PumpMotor P-Base 16.5 in:1", "Project", "Part Number") = "HO100P2BLG"
			ElseIf PartNumber = "PHO100P2SLG" Then
				iProperties.Value("PumpMotor P-Base 16.5 in:1", "Project", "Description") = "MOTOR, 100HP, 1800RPM, 230/460V, PE"
				iProperties.Value("PumpMotor P-Base 16.5 in:1", "Project", "Part Number") = "PHO100P2SLG"
			ElseIf PartNumber = "HO100S2BLG" Then
				iProperties.Value("PumpMotor P-Base 16.5 in:1", "Project", "Part Number") = "HO100S2BLG"
			ElseIf PartNumber = "HO100V2SLG" Then
				iProperties.Value("PumpMotor P-Base 16.5 in:1", "Project", "Description") = "MOTOR, 100HP, 3600RPM, 143T, 230/460V, TEFC"
				iProperties.Value("PumpMotor P-Base 16.5 in:1", "Project", "Part Number") = "HO100V2SLG"
	ElseIf HP = "125 HP" Then
		'set list
		MultiValue.SetList("PartNumber", "HO125P2SLG", "HO125V2SLG")
		'set default value
		Parameter("PartNumber") = "HO125P2SLG"
			If PartNumber = "HO125P2SLG" Then
				iProperties.Value("PumpMotor P-Base 16.5 in:1", "Project", "Description") = "PUMP MOTOR, 125HP - 1800RPM, 460/3/60"
				iProperties.Value("PumpMotor P-Base 16.5 in:1", "Project", "Part Number") = "HO125P2SLG"
			ElseIf PartNumber = "HO125V2SLG" Then
				iProperties.Value("PumpMotor P-Base 16.5 in:1", "Project", "Part Number") = "HO125V2SLG"
	ElseIf HP = "150 HP" Then
		'set list
		MultiValue.SetList("PartNumber", "PHO150P2SLG", "HO150S2SLG")
		'set default value
		Parameter("PartNumber") = "PHO150P2SLG"
			If PartNumber = "PHO150P2SLG" Then
				iProperties.Value("PumpMotor P-Base 16.5 in:1", "Project", "Description") = "PUMP MOTOR, 150HP - 1800RPM, 460/3/60"
				iProperties.Value("PumpMotor P-Base 16.5 in:1", "Project", "Part Number") = "PHO150P2SLG"
			ElseIf PartNumber = "HO150S2SLG" Then
				iProperties.Value("PumpMotor P-Base 16.5 in:1", "Project", "Part Number") = "HO150S2SLG"
End Sub
WCrihfield
HI @Preston_Reed.  When you use multi-value text type parameters as the source of a drop-down list for an iLogic Form, you are basically at the mercy of Inventor's built-in sorting system for those values.  Even if you put the values into the list in the order you want them, Inventor automatically re-sorts them its own way.  It does not recognize that 120 is a greater numerical value than 25 because it is only comparing each character in the first position first, then the character in position 2, and so on.  The character 2 in 25 is greater than the character 1 in 120, so it will always position 25 higher in the list than 120.  If the multi-value parameter were numerical type, instead of text type, then it would recognize the whole numerical values and put them in the correct order.  Did you know that Inventor actually does have Horse Power "hp" available as one of the Units you can choose from?  You could delete that Multi-Value parameter, and re-create it as numerical, and set its units to "hp" (lower case), then it should sort more properly for you.
Wesley Crihfield
(Not an Autodesk Employee)
Preston_Reed
@WCrihfield  thank you again, ill mess around with this and see if I can make it look better, Ill probably add that to the ideas forum too, I could see sorting be useful to others
Preston_Reed
@WCrihfield , i forgot to ask the question i was trying to figure out the most.  In this case, following the gif above, I have to select which HP rating i want, then push apply so that the PartNumber list is updated then I have to select PartNumber then push apply again.  Is there a way to update PartNumber as soon as I pick a HP rating?
Current Process: HP selection-> push apply ->PartNumber selection -> push apply
Ideal Process: HP Selection -> PartNumber selection -> push apply
WCrihfield
Hi @Preston_Reed.  If your iLogic Form was an 'internal' one, instead of a 'global' one, it would work that way.  Unfortunately, when working with global iLogic forms, there is a slight disadvantage in performance/functionality.  Since you want your code to run to filter available options based on first option chosen, and you are using a global form, you will have to either click apply each time, or click a 'run rule' type of button (when you drag an iLogic rule into your form, it becomes a button, and you can set what all happens when you click it).  Either way, it involves more clicks when compared to using a local/internal iLogic form.
Wesley Crihfield
