Trying to move the camera to a point in iLogic. What am I doing wrong?
ianteneth
ianteneth
I have a simple iLogic script to move the camera to a point (See code below). This code will look at the origin from 15(cm?) away. In 2020 it works fine and will move to the origin as well as zoom to 15. But in 2021 this same code will only move the camera to the origin, not zoom. There are some screenshots of the results below also.
Edit: Just tested 2018 and it also doesn't zoom, just moves to the origin.
Question(s): Can anyone reproduce this or am I doing something wrong? Maybe this is a bug?
Dim camera As Camera = ThisApplication.ActiveView.Camera
camera.Target = ThisApplication.TransientGeometry.CreatePoint(0, 0, 0)
camera.Eye = ThisApplication.TransientGeometry.CreatePoint(15, 15, 15)
camera.Apply()
In 2021 the camera doesn't zoom.
In 2020 the camera zooms fine.
marcin_otręba
Maybe you should use fit method:
camera.Fit
camera.Apply()
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
ianteneth
Hi @marcin_otręba,
Thanks for the feedback. I tried adding the Fit method, but, it just fits the entire model into the view, not the target point.
ckeveryga
This should work for you. May need to play with extent values.
camera.SetExtents(15,15)
camera.Apply()
