Traverse Assembly and create total cost while filtering some properties
tracey
Message 1 of 19
tracey
I found this code by E_Jeph and altered it to traverse through an assembly, ignore parts that are reference, phantom or material 'copper' and add up the cost of all to create a total.  It only does this for the top assembly despite the recursive to traverse through all sub assemblies.  I have tackled this every which way.  I have a leaf occurrence rule that I could adapt but I need to get values from some assemblies as well as parts, so it needs to look at all.  Can anyone see why this won't look at sub assemblies and parts? The blue text may need altering.  Really stuck here so any help would be appreciated.  Thank you.
Sub Main TraverseAssemblySample()
    ' Get the active assembly.
    Dim oAsmDoc As AssemblyDocument
    oAsmDoc = ThisApplication.ActiveDocument
    Dim oCost As Decimal
    oCost = 0
    ' Call the function that does the recursion.
    Call TraverseAssembly(oAsmDoc.ComponentDefinition.Occurrences, 1, oCost)
    MsgBox(oCost)
End Sub
Private Sub TraverseAssembly(ByVal Occurrences As ComponentOccurrences, _
ByVal Level As Integer, _
ByRef oCost As Double)
    ' Iterate through all of the occurrence in this collection.  This
    ' represents the occurrences at the top level of an assembly.
    For Each oOcc As ComponentOccurrence In Occurrences
' Skip Phantom and reference parts.
If oOcc.BOMStructure = BOMStructureEnum.kPhantomBOMStructure _
Or oOcc.BOMStructure = BOMStructureEnum.kReferenceBOMStructure Then
                        ' Do Nothing
                Else
        ' The occurrence is valid count the cost.
        ' Get the document file for this occurrence
        Dim oDoc As Document
        oDoc = oOcc.Definition.Document
        ' Get the iPropertySet that constains the estimated cost property
        Dim oPropSet As PropertySet
        oPropSet = oDoc.PropertySets.Item("Design Tracking Properties")
        ' Get the cost of this occurrence
        oCost += oPropSet.Item("Cost").Value
        ' Check to see if this occurrence represents a subassembly
        ' and recursively call this function to traverse through it.
        If oOcc.DefinitionDocumentType = kAssemblyDocumentObject Then
            Call TraverseAssembly(oOcc.SubOccurrences, Level + 1, oCount)
    Next
End Sub
Accepted solutions (3)
Replies (18)
Message 2 of 19
JhoelForshav
Made some changes to the code
    oCost = TraverseAssembly(oAsmDoc.ComponentDefinition.Occurrences)
    MsgBox(oCost)
End Sub
Private Function TraverseAssembly(ByVal Occurrences As ComponentOccurrences) As Decimal
	Dim oCost As Decimal = 0
                Else
           oCost += TraverseAssembly(oOcc.Definition.Occurrences)
    Next
	Return oCost
End Function
Seems to me that the ByRef argument oCost didnt work as expected for multiple levels like that.
This should work 🙂
Message 3 of 19
JhoelForshav
I posted something here that i left some junk in the code. Saw that i could edit replys later. So ignore this...
Message 4 of 19
tracey
Thank you for being willing to help though!
Message 5 of 19
JhoelForshav
Maybe my posts was a little confusing. The code in my first reply should work... Just meant that i left some messageboxes etc. in there at first but it's edited now.
Please accept as solution if it works for you 🙂
Message 6 of 19
tracey
Thank you.. it works a treat!
Message 7 of 19
tracey
One more question.  If I suppress a file or subassy the rule throws an exception until I reverse the suppression!  Why would it find this problematic?  Do I have to add script to tell it to ignore suppressed files?
Message 8 of 19
JhoelForshav
    MsgBox(oCost)
End Sub
'Skip suppressed
If oOcc.Suppressed = False Then
                Else
    Next
	Return oCost
End Function
Does it work for you to simply skip supressed occurrences like this? or do you want to include cost of suppressed components too?
Message 9 of 19
tracey
Hi,  I don't need to add in the cost of suppressed files.  When I suppress a file, this rule still throws an exception even with your addition Smiley Indifferent  very odd.
Message 10 of 19
JhoelForshav
hmm... I'll take a look at it. Check that you got the latest version of my reply though. I edited it because first i acidentally put if oOcc.Suppressed = True. It should be if oOcc.Suppressed = False obviouslySmiley Very Happy
Message 11 of 19
JhoelForshav
I can't seem to replicate your problem. But if you've checked that you got the latest cody as described in previous post you could try a simple try-catch instead... If that doesnt work i think i'll need an assembly-file from you to test the code in in order to replicate the problem.
But first, try this 🙂
	MsgBox(oCost)
End Sub
		Try
			Else
		Catch
		End Try
	Next
	Return oCost
End Function
Message 12 of 19
tracey
This works fine now. 🙂
Thank you
Message 13 of 19
tracey
Hi, I have a final question.  How to I capture the returned value.  I have tried a line after it such as:  iProperties.Value("Custom", "BOM_Price") = oCost
oCost being the Value returned by oCost.  I am trying to save the returned value somewhere so I can use it later.  Any ideas?
Message 14 of 19
JhoelForshav
Do i understand correctly that you want to store the calculated value in a custom iProperty named BOM_Price?
Message 15 of 19
tracey
Hi, yes that’s what I would like to do so I can access the value later In a drawing.
thank you for your help!
kind regards
Tracey
Message 16 of 19
JhoelForshav
Try this as your main sub:
	Dim oCustomProps As PropertySet = oAsmDoc.PropertySets.Item("User Defined Properties")
	Dim oProperty As Inventor.Property
	Try
	'Try to access the property BOM_Price
	oProperty = oCustomProps.Item("BOM_Price")
	Catch
	'If failure, assume property doesn't exist and create it
	oProperty = oCustomProps.Add(0,"BOM_Price")
	End Try
	'Custom properties doesn't seem to like datatype decimal, so i put in the value as a double.
	oProperty.Value = CDbl(oCost)
End Sub
Message 17 of 19
JhoelForshav
Or like this if you want to include a dollar sign for example:
Try
Catch
oProperty = oCustomProps.Add("","BOM_Price")
End Try
'oCost = TraverseAssembly(oAsmDoc.ComponentDefinition.Occurrences)
oProperty.Value = oCost.ToString & " $"
End Sub
Message 18 of 19
tracey
Thank you for helping Smiley Happy Seems to work well.  This code creates a custom property called "BOM_Price, traverses the assembly, skips reference and phantom parts and all "Copper" parts.  Adds up the cost and puts the value in the custom iProperty so I can use it elsewhere.  Here is the final code:
Sub Main()
'Call the function that does the recursion.
        Try
'    'try to access the property BOM_Price
        Catch
'    'If failure, assume prop doesnt exist and create it
            oProperty = oCustomProps.Add("", "BOM_Price")
        End Try
'    'Call the function that does the recursion.
MsgBox(oCost)
    End Sub
    Dim TotalCost As Decimal = 0
            Dim oBrowserNode As String
            oBrowserNode = oOcc.Name
            Try
                If oOcc.BOMStructure = BOMStructureEnum.kPhantomBOMStructure Or
                oOcc.BOMStructure = BOMStructureEnum.kReferenceBOMStructure Or
                iProperties.MaterialOfComponent(oBrowserNode) = "Copper" Then
            Else
    Catch
    End Try
    Next
    'iProperties.Value(Name, "Custom", "BOM_Price") = oCost
    Return oCost
End Function
Message 19 of 19
rcoi
2023. This code works excelent. Thank you
