Translation VBA > iLogic
TONELLAL
TONELLAL
I have an iLogic rule with a sub :
Sub Modif_part(oPart As PartDocument)
End sub
 Is it possible to use on oPart syntax for parts, like
iProperties.PartColor="XXX"
or
p = Parameter.Param("YYY") ?
Or I have to use the VB syntax :
oPart.ActiveRenderStyle=oPart.RenderStyles.item("XXX")
or
p=oPart.ComponentDefinition.Parameters.UserParameters.item("G_T").Value
MegaJerk
If you're using VBA, then you'll need to use the long form version
I believe that the reason you can use those nifty little short hand versions in iLogic, are due to the delegates used when whoever happened to make iLogic (which was originally an outside plugin if I have my history correct) designed it.
You could of course create some classes that take the place of those easy to use keywords that you find in iLogic, but you'd need to make them.
If my solution worked or helped you out, please don't forget to hit the kudos button 🙂
iLogicCode Injector: goo.gl/uTT1IB
GitHub
TONELLAL
In fact I had initially a very simple rule like :
select case G_T
case 10
properties.partcolor="red"
case 20
properties.partcolor="green"
This rule was in the part. I'd prefer to have an external rule, so I have to scan all the assembly to apply the rule to all parts. I re-wrote the rule in VBA, it functions. I have modified the code to adapt it to iLogic (in fact only deleted all "SET"), it fucntions. I wondered I  could use the specific iLogic syntax only to simplify the code.
Not sure if this applies, but in ilogic you can use the:
"Imports Inventor" statement and then use inventors objects as you like.
TONELLAL
Ok, so it seems I can't simplify my iLogic code. So I'll use iLogic as if it was VBA...
