iLogic to control End of Part
fakeru
fakeru
Hi!
Is it possible to control (move) End of Part with iLogic? Let's say to move it before or after a certain feature.
Regards
Alexandru
Autodesk Inventor 2015 Certified Professional
fakeru
I found it. I case someone will need it here is the code:
Feature.InventorFeature("Feature Name").SetEndOfPart(True)
This will move EoP before feature "Feature Name".
what if the feature is a 3d sketch?
Nevermind. Figured it out.
Dim 3DSketches As Sketches3D =  ThisApplication.ActiveDocument.ComponentDefinition.sketches3D
Dim oSketch As Sketch3D = sketches.Item("sketch1")
oSketch.SetEndOfPart(true)
This is a great feature to move it before or after a certain feature, but how do you move the EOP marker back to the end of part with iLogic?
bshbsh
ThisDoc.Document.ComponentDefinition.SetEndOfPartToTopOrBottom(False)
This works great!! Thank you for your knowledge, have a great day!
