transientObjects problems
I've been trying to mirror a feature in a part document using VB and I cant seem to get it right. I keep getting an error: run-time error '429' activex component can't create object
Can anyone help me with this???
Dim oParentFeatures As ObjectCollection
" I get this problem at the line below"
Set oParentFeatures = ThisApplication.TransientObjects.CreateObjectCollection
oParentFeatures.Add oExtFeature
Dim oMirror As MirrorFeature
Set oMirror = oPartDoc.ComponentDefinition.PartFeatures.MirrorFeatures.Add(oParentFeatures, oWorkPlane)
ThisApplication is valid only if you are using VBA. If you are using VB, you
can either get a reference to the active Inventor application or create one
as follows:
On Error Resume Next
'obtain the Inventor object if it is already open
Set oInventorApp = GetObject(, "Inventor.Application")
'if Inventor is not open then create Inventor object
If Err Then
'create and access Inventor's Application object
Set oInventorApp = CreateObject("Inventor.Application")
End If
On Error GoTo 0
Also, the line to create the mirror feature should be (replace PartFeatures
with Features):
Set oMirror =
oPartDoc.ComponentDefinition.Features.MirrorFeatures.Add(oParentFeatures,
oWorkPlane)
-Venkatesh Thiyagarjan.
wrote in message news:5120485@discussion.autodesk.com...
Set oMirror =
oWorkPlane)
