TransactionManager - documentation
Rene_Gerlach
Rene_Gerlach
Hi @Anonymous,
can someon explain the
TransactionManager._StartUnidentifiedTransaction and
TransactionManager.StartTransactionWithOptions - what options possible?
where is nothing in the API documentation
Rene
AlexFielder
I'm not sure where you got the 'StartTransactionWithOptions' method from, but this page has more on transactions:
http://help.autodesk.com/view/INVNTOR/2019/ENU/?guid=GUID-EB4D4D34-C84F-494A-8665-D87EF536B38F
The above applies to Inventor 2019, maybe your method has been deprecated?
Rene_Gerlach
Hi Alex,
yes it's not documented, thats why I ask here 😉
I got both function from the object library (.tlb).
Regards
Rene
AlexFielder
In that case it's an internal method and wouldn't be expected to be documented anywhere outside of Autodesk's castle.
Which .tlb are you getting that from?
Rene_Gerlach
--> From the official RxInventor.tlb, delivered with Inventor self.
AlexFielder
In that case I would leave it well alone. The only non-documented file(s) I've ever pulled anything useful from over the years are the Autodesk.iLogic.Interfaces.dll and the Autodesk.iLogic.Runtime.dll both of which have accompanying .xml files.
And even then, most of the "functions" available within those files are now in the official documentation.
chandra.shekar.g
Autodesk Support
Autodesk Support
@Rene_Gerlach ,
Yes, methods are hidden API. So, no documentation for this methods.
You can enable hidden objects to view in VBA editor by browsing respective objects.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
