Top Level Browser Node
NachoShaw
Advisor Advisor
NachoShaw
Hi
In a part, is it possible to hook into the right click menu of the top level node Solid Bodies folder to add an extra button?
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
JelteDeJong
its possible to do this by catching the "OnContextMenu" event.
C#
inventor.CommandManager.UserInputEvents.OnContextMenu += onContextMenu;
And  then checking if the top node was selected.
c#
private void onContextMenu(SelectionDeviceEnum SelectionDevice, NameValueMap AdditionalInfo, CommandBar CommandBar)
// random ControlDefinition for demo ControlDefinition oCtrlDef = inventor.CommandManager.ControlDefinitions["AppZoomAllCmd"]; // check if the menu is in the browser if (SelectionDevice == SelectionDeviceEnum.kBrowserSelection) { Document oDoc = inventor.ActiveDocument; // loop over all BrowserNodes under topnode. // pay attension for sheetmetal parts because the node tree is different! foreach (BrowserNode node in oDoc.BrowserPanes["Model"].TopNode.BrowserNodes) { // check if the selected node is the "Solid bodies" node. if (node.Selected == true && node.BrowserNodeDefinition.Label.Contains("Solid Bodies(")) { // add your ControlDefinition to the menu/CommandBar CommandBar.Controls.AddButton((ButtonDefinition)oCtrlDef, 1); } } } }
Here i added the zoom all control
Jelte de Jong
Blog: hjalte.nl - github.com
