ilogic coding Error - Please help!
I can't figure out what is wrong with this... I'm trying to open all drawings whose filename contains the project number. If i remove the "For each subOcc...." part it works fine. It seems to error out at the "oCurrentFilenameWithExtension = oOcc.ReferencedFileDescriptor.FullFileName" Line on the first sub occurence.
Error shown under my rule.
Also "ThisApplication.ActiveView.Fit" seems to be doing sweet FA
Class ThisRule
	Dim ComponentArray As New ArrayList
Sub Main
	Dim oDoc As AssemblyDocument = ThisApplication.ActiveDocument
	Dim oCompDef As AssemblyComponentDefinition = oDoc.ComponentDefinition
	Dim oOcc_s As ComponentOccurrences = oCompDef.Occurrences
	'look at each occurrence in the assembly
	For Each oOcc As ComponentOccurrence In oOcc_s
		OpenDrawing(oOcc)
	Next
	MessageBox.Show("Please Check for Overlapping Dimensions, then Check in to Vault.", "All Drawings Have Been Generated")
End Sub
Sub OpenDrawing(oOcc)
	oCurrentFilenameWithoutExtension = oCurrentFilenameWithExtension.Substring(0, oCurrentFilenameWithExtension.Length - 4)
	If oOcc.Name.Contains(Project_Folder) And ComponentArray.Contains(oCurrentFilenameWithExtension) = False
		ComponentArray.Add(oCurrentFilenameWithExtension)
		Dim DrawingDoc As DrawingDocument = ThisApplication.Documents.Open(oCurrentFilenameWithoutExtension & ".dwg", True)
		DrawingDoc.Save
		For Each subOcc As ComponentOccurrence In oOcc.SubOccurrences
			OpenDrawing(subOcc)
		Next
End Sub
End Class
JamieVJohnson2
break this line up into 2 operations
rfd=oocc.ReferencedFileDescriptor
oCurrentFilenameWithExtension =rfd.FullFileName
you will find that rfd is nothing in some situation. use an if statement to clarify before continuing:
if rfd isnot nothing then
'and all your other code...
end if
Jamie Johnson : Owner / Sisu Lissom, LLC https://sisulissom.com/
Thanks.
It must have been the weld bead that it was the culprit.
