Titleblock with Prompted Texts got error when switch
kevinNSZML
kevinNSZML
Hello, when I use the following iLogic code as my external rule, I got an error when I switch to other title blocks. If I delete all prompt entries from title blocks, then it works perfectly.
ThisDrawing.ResourceFileName = "D:\Inventor_Template\A4_Template.idw"
ActiveSheet.ChangeSize("A4")
ActiveSheet.ChangeSize(211,297)
ActiveSheet.TitleBlock = "AX_H"
ActiveSheet.Border = "A4_H"
ThisApplication.ActiveView.Fit
I have been using this code for more than a year, recently I added prompt texts to all title blocks. After I added it, I can't use illogic code to quickly switch. It always says an error occurred on this row: ActiveSheet.TitleBlock = "AX_H"
But, manually switching titleblocks is fine. Does anyone have an idea to figure out this problem? Thanks
(To be clear, prompt texts here means, https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-708CC945-36C4-4402-AB99-4403FFAB1878)
A.Acheson
Hi @kevinNSZML
From the activesheet you should have access to the "SetTitleBlock" method. This is where you can set the prompted entry titles. See ilogic API help here
Dim titleBlockName As String = "TitleBlockName"
Dim sPromptStrings(1) As String sPromptStrings(0) = "String 1" sPromptStrings(1) = "String 2"
ActiveSheet.SetTitleBlock(titleBlockName,sPromptStrings)
Regards
Alan
kevinNSZML
It works perfectly, thank you so much!
