Threaded holes while logged off using API
ZKeimW5SN7
Message 1 of 16
ZKeimW5SN7
We are using Inventor on a computer that has a C# console application querying a database for “work to do.” This console application is started by a task that launches the console application at the machine’s startup, and it runs in the background whether a person is logged into the machine or not. Once the query returns a part to draw, it goes in, draws the part, and outputs it to a specified location. This works great for most things; however, we noticed it would always throw an “unable to invoke object” error while trying to create a threaded hole. Then we noticed that if the user was logged in, it would work every time. Does a user HAVE to be logged in to use the Inventor API without errors?
Replies (15)
Message 2 of 16
YuhanZhang
Did you test with a different machine for this?  Can you share more detailed info about the error?
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
Message 3 of 16
ZKeimW5SN7
Yes, we have 2 separate machines that have this issue.  We have a "TEST" machine and a "Production" machine.
The error comes from this line in our code:
cSE.oIHoleTapInfo = cSE.oIHoleFeatures.CreateTapInfo(true, "ANSI Unified Screw Threads", x.ToUpper(), "2B", false, dDrillDepth);
example inputs of the variables are:
x = 1/2-13 UNC
dDrillDepth = 1.5
Here is some of the settings on our task that we use to start the program.  If we use the top setting, everything works.  If we use the bottom setting, we get the error.  I believe it says: "Unable to invoke object".
Message 4 of 16
YuhanZhang
Which Inventor version are you working with? Where you placed your app for startup? If you configured the app as startup app for specified user to log in, it may require the user to log in.
Please share your steps to configure your startup app, so we can check if this is Windows limitation or Inventor side issue.
Rocky Zhang
Inventor API PD
Autodesk, Inc.
Message 5 of 16
ZKeimW5SN7
It's Autodesk Inventor Processsional 2023 64 bit edition
Build 446, Release 2023.5
Message 6 of 16
YuhanZhang
We did a test here for CreateTapInfo, and it succeeded without logging in. Can you share more info that might be a reason to cause this problem?
Rocky Zhang
Inventor API PD
Autodesk, Inc.
Message 7 of 16
ZKeimW5SN7
We have a function that starts inventor when the request is an Inventor request.  If it's not (other CAD platforms) they have a similar function.  Inventor remains open unless it crashes.  If it does, or the computer is restarted, this function will open inventor and attach the process to it on the first requests that requires it.
public static void StartInventor()
try
string sName = "";
int loop = 0;
foreach (Process Proc in Process.GetProcesses())
if (Proc.ProcessName.Equals("Inventor"))
if (loop > 0)
DebugLog("before kill process inventor");
killInventor();
DebugLog("after kill process inventor");
else
sName = Proc.ProcessName;
loop++;
if (sName == "")
Process.Start(@"C:\Program Files\Autodesk\Inventor 2023\Bin\Inventor.exe");
bool found = false;
int count = 0;
while (!found && count < 60)
try
System.Threading.Thread.Sleep(1000);
count++;
cSE.oInventorApp = (Inventor.Application)Marshal.GetActiveObject("Inventor.Application");
found = true;
catch
DebugLog("attempts to get inventor process " + count.ToString());
if (!found)
cSE.oInventorApp = null;
throw new Exception("Inventor start timed out");
else
_InvapplicationEvents = cSE.oInventorApp.ApplicationEvents;
_InvassemblyEvents = cSE.oInventorApp.AssemblyEvents;
_InvmodelEvents = cSE.oInventorApp.ModelingEvents;
if (!IsINVInit)
_InvapplicationEvents.OnOpenDocument += oIAppEvents_OnOpenDocument;
_InvapplicationEvents.OnSaveDocument += oIAppEvents_OnSaveDocument;
_InvapplicationEvents.OnCloseDocument += oIAppEvents_OnCloseDocument;
_InvapplicationEvents.OnInitializeDocument += oIAppEvents_OnInitializeDocument;
_InvapplicationEvents.OnReady += oIAppEvents_OnReady;
_InvassemblyEvents.OnNewOccurrence += oIAssemblyEvents_OnNewOccurrence;
_InvassemblyEvents.OnOccurrenceChange += oIAssemblyEvents_OnOccurrenceChange;
_InvassemblyEvents.OnAssemblyChange += oIAssemblyEvents_OnAssemblyChange;
_InvassemblyEvents.OnAssemblyChanged += oIAssemblyEvents_OnAssemblyChanged;
_InvmodelEvents.OnNewFeature += oIModelEvents_OnNewFeature;
IsINVInit = true;
//if (cFG.cServer == "DEV")
cSE.oInventorApp.Visible = true;
cSE.oInventorApp.WindowState = kMaximize;
cSE.oInventorApp.SilentOperation = true;
cSE.oIDocs = cSE.oInventorApp.Documents;
cSE.oITransGeo = cSE.oInventorApp.TransientGeometry;
cSE.oITransObj = cSE.oInventorApp.TransientObjects;
catch (Exception ex)
ErrorLog(ex);
throw (ex);
Message 8 of 16
ZKeimW5SN7
Sorry, I saw a previous message and was replying to that, the page didn't scroll to the appropriate reply...
I will get with my CAD developer to answer your latest question.
Message 9 of 16
ZKeimW5SN7
I asked my developer to create a small sample program that will do only this one thing so we can have something to share.  In the meantime, I thought it might be good to make clearer an observation about these settings.  This issue happens if you are logged in or not.  We can start this task ask the second option, leave the computer logged in, run the CAD request and it will fail.  Turn this setting the other way as shown below, and you it works every time.
Here are the other settings of the task that starts our console application.
Message 10 of 16
YuhanZhang
If you can provide us a sample project and how you configure it via Task Scheduler, then we can try to reproduce it here.
Rocky Zhang
Inventor API PD
Autodesk, Inc.
Message 11 of 16
YuhanZhang
Hi @ZKeimW5SN7 ,
I got your project and tested here, I created a task in Task Scheduler as below and it works well:
Here is the log result:
Can you double check it there?
Rocky Zhang
Inventor API PD
Autodesk, Inc.
Message 12 of 16
ZKeimW5SN7
Hi Rocky,
Did you run it while signed out?  I created the sample project and tested it the day I sent it in.  The error only happens when the user is not currently logged in, so the best way to do that is restart the computer and let the task start on its own when the computer turns back on.
Message 13 of 16
YuhanZhang
Hi @ZKeimW5SN7
I added some code to your project to show the active user when the task is running, and I saw the problem, i.e. the task is ran when a user logon(even I restarted machine), so I changed the "Security options:" to use System account instead of a user account, and now it works as below:
The System is a built-in account which can run the task before any users log on. So can you make sure you set it to System instead of a user account?
Rocky Zhang
Inventor API PD
Autodesk, Inc.
Message 14 of 16
ZKeimW5SN7
I tried it, and now it errors when trying to start Inventor. Here is my task scheduler:
  I assume it's not getting past the login type security built into Inventor.
I then tried it locally to see if there were any error messages and I got:
“Inventor.exe is not currently registered and did not re-register on start up. This is probably because you do not have enough access rights (e.g. you are a restricted user). Ask an administrator or standard user to re-run the program for you.”
Message 15 of 16
YuhanZhang
Hi @ZKeimW5SN7 is your machine configured by your IT? You can check if your System account has full control to Inventor.exe:
If not you can grant it permission and then try it again.
Rocky Zhang
Inventor API PD
Autodesk, Inc.
Message 16 of 16
ZKeimW5SN7
Hi @YuhanZhang,
Yes, I already had the same settings as you on inventor.exe security:
Anything else you can think of that I should check?
