Thread Error
Thread Error
Thread Error
hello
I have a rule in part, to scale automatically when the file is opened.
I am encountering error when performing the thread in the rule.
in line to apply the new thread, the following error appears:
Sub Main()
If DI>=DE Then
   MessageBox.Show("Diametro Interno NaO pode ser superior ao Externo", "Title")
   Return
End If
Parameter("diam_ext") = DE
Parameter("diam_int") = DI
Parameter("compr") = L
 If temrosca = "TRUE" Then
    Feature.IsActive("Rosca_Graxeira")="True"
    Feature.IsActive("Furo_grax")="True"
    Feature.IsActive("Chanfro_rosca")="True"
    If rosca = "1/8 BSP"  Then
            diam_rosca = "8.8"
            Feature.SetThread("Rosca_Graxeira", "BSP Pipe Threads", "G 1/8-28", "")
    ElseIf rosca = "1/8 GAS" Then
            diam_rosca = "8.55"
    ElseIf rosca = "1/8 NPT" Then
            diam_rosca = "8.70"
            Feature.SetThread("Rosca_Graxeira", "NPT", "1/8 -27NPT", "")
    ElseIf rosca = "3/8 BSP" Then
            diam_rosca = "15.3"
            Feature.SetThread("Rosca_Graxeira", "BSP Pipe Threads", "G 3/8-19", "")
    ElseIf rosca = "M10 x 1" Then
            diam_rosca = "9"
            Feature.SetThread("Rosca_Graxeira", "ANSI Metric M Profile", "M10x1", "6H")
    ElseIf rosca = "M6 x 1" Then
            diam_rosca = "5"
            Feature.SetThread("Rosca_Graxeira", "ANSI Metric M Profile", "M6x1", "6H")
    ElseIf rosca = "M8 x 1" Then
            diam_rosca = "7"
            Feature.SetThread("Rosca_Graxeira", "ANSI Metric M Profile", "M8x1", "6H")
    ElseIf rosca = "M8 x 1,25" Then
            diam_rosca = "7.75"
            Feature.SetThread("Rosca_Graxeira", "ANSI Metric M Profile", "M8x1.25", "6H")
    End If
    Parameter.UpdateAfterChange = True
 Else
    Feature.IsActive("Rosca_Graxeira")="False"
    Feature.IsActive("Furo_grax")="False"
    Feature.IsActive("Chanfro_rosca")="False"
    Return
 End If
 Return
End Sub
Try removing the "8.8" from the dimension assignment.
diam_rosca = 8.8
etc.
