There are not enough quotas to process the command
anton.gorschnev
anton.gorschnev
when exiting sketch editing (sketch.ExitEdit()), after drawing a large number of points (if oHolPoint.HoleCenter = True more than 9000, if oHolPoint.HoleCenter = False more than 6000) the System error pops up.ComponentModel.Win32Exception
HResult=0x80004005
Message = Not enough quotas to process the command
Michael.Navara
I can't confirm it. I try following code without any issues (Inv 2023)
Dim sketch As PlanarSketch = ThisApplication.ActiveEditObject
Dim start = DateTime.Now
sketch.DeferUpdates = True
For x As Integer = 0 To 100
	For y As Integer = 0 To 100
		sketch.SketchPoints.Add(ThisApplication.TransientGeometry.CreatePoint2d(x, y))
	Next
Next
sketch.DeferUpdates = False
sketch.Solve()
sketch.ExitEdit()
Dim duration = DateTime.Now - start
Logger.Debug(duration.TotalSeconds)
anton.gorschnev
anton.gorschnev
anton.gorschnev
it helps to draw points without entering edit mode, but performance decreases significantly. maybe the problem is in the old version of the Inventor 2014.
