TextBox from Definition to Result
I'm doing a fault check routine before batch plotting, and one of the issues is to make sure the TextBox's Property is showing the latest result.  So far I can get the actual text box I'm after, but I want to be able to see the evaluated text, not just the definition.
Values in Watch windows (VS 2012) display the definition of a property, but not the result:
Textbox.FormattedText "<PhysicalProperty PhysicalPropertyID='72449' Precision='0'>MASS</PhysicalProperty>"
TextBox.Text "<MASS\P0;>"
Is there a way I can see the Result of that expression, from the current idw/dwg drawing document's 'about to print' point of view?
I'm determined to solve the 'N/A' issue with properties that change in the background.
(PS I am currently using the 2015 API)
Thank you,
Vladimir.Ananyev
iProperty object expose not only Expression contained in this property but also Value property that returns evaluated value.
If you use expression like  "<PhysicalProperty PhysicalPropertyID='72449' Precision='0'>MASS</PhysicalProperty>" in your own interface you should implement calculations by yourself.
cheers,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
