Text Size Change ilogic
M_Santi
Message 1 of 10
M_Santi
I am trying to change the text size of a custom Iproperty using Ilogic. Is it possible to use a parameter to change the text size of a custom Iproperty text? I want to create a form using parameters to change the text size of each individual custom iproperty text.
Replies (9)
Message 2 of 10
A.Acheson
Hi @M_Santi
Here is a method to access the titleblock formatted text font. Hopefully that will help you.
Dim doc As DrawingDocument = ThisApplication.ActiveDocument
Dim sht As Sheet = doc.ActiveSheet
Dim tb As TitleBlock = sht.TitleBlock
Dim tbSketch As Sketch
tb.Definition.Edit(tbSketch)
For Each txtBox As Inventor.TextBox In tbSketch.TextBoxes
    If txtBox.FormattedText.Contains("CUST PART#")  Then
        txtBox.Style.FontSize = 0.3
Next
tb.Definition.ExitEdit(True)
Regards
Alan
Message 3 of 10
M_Santi
It's not working, I'm getting an error.
Message 4 of 10
Curtis_Waguespack
Hi @M_Santi
That error would suggest that there might not be an instance of the title block placed on the active sheet of the drawing.
Can you confirm that there is a title block on the sheet?
I hope this helps.
Curtis
Message 5 of 10
M_Santi
I got the code to work but did not solve what I wanted the code to do. I want.
iProperties.Value("Custom", "CUST PART#")
to be the only one that changes font size. The other custom properties font size changes with it.
Message 6 of 10
M_Santi
I found one that kinda works, but I want to change the fontsize and not WidthScale.
Dim
oTG As TransientGeometry oTG = ThisApplication.TransientGeometry Dim oDoc As DrawingDocument oDoc = ThisApplication.ActiveDocument Dim oSheet As Sheet oSheet = oDoc.ActiveSheet Dim oTB As TitleBlock oTB = oSheet.TitleBlock Dim oDef As TitleBlockDefinition oDef = oTB.Definition 'open sketch in edit mode Dim oSketch As DrawingSketch Call oDef.Edit(oSketch) Dim oTextBoxes As TextBoxes oTextBoxes = oSketch.TextBoxes Dim oBox As TextBox For Each oBox In oTextBoxes If oBox.Text = "<CUST PART#>" Then 'The text parameter you want to change Call oDef.Edit(oSketch) oBox.WidthScale = 0.8 Call oDef.ExitEdit(True) End If Next InventorVb.DocumentUpdate()
Message 7 of 10
A.Acheson
Hi @M_Santi
If the style change is not acceptable then you can overide the font of the attribute manually then run formatted text code again and send it to the logger.Info(). The overide font should appear in the formatted text.
		Logger.Info(txtBox.Text)
		Logger.Info(txtBox.FormattedText)
		txtBox.FormattedText ="<StyleOverride FontSize='0.61'><Property Document='drawing' PropertySet='User Defined Properties' Property='CUST PART#' FormatID='{D5CDD505-2E9C-101B-9397-08002B2CF9AE}' PropertyID='5'>CUST PART#</Property></StyleOverride>"
Next
Regards
Alan
Message 8 of 10
M_Santi
It works to a certain extent. Is it Possible to use a parameter to determine the font size? I want to create a form using the parameter to change the font size.
Message 9 of 10
A.Acheson
Hi @M_Santi
Yes you can concatenate the string found with the parameter.
Dim fontsize as String = "0.61"
txtBox.FormattedText ="<StyleOverride FontSize='" & fontsize & "'.........write rest of text"
Regards
Alan
Message 10 of 10
M_Santi
Thank you, this works perfectly of how I want it.
