Initial View Scale with VBA
0x3FA5
0x3FA5
I tried to find some hints on the Inventor API help webpage, but no real success there..
Please help me to do the following.
How do I change this parameter in the drawing:
Located here (Title Block):
To this:
Using VBA macro?
Thank you!
* Update *
After further researching I identified that the Item(55) holds the information required, and came up with the following code:
Option Explicit
Sub DrwScale()
Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
Set oSheet = oDoc.ActiveSheet
Dim oTitleBlock As TitleBlock
Set oTitleBlock = oSheet.TitleBlock
oTitleBlock.Definition.Sketch.TextBoxes.Item(55).FormattedText = "<DerivedProperty DerivedID='29707'>Initial View Scale</DerivedProperty>"
End Sub
Which produces the following error:
I guess, the issue is that I incorrectly filled the FormattedText property.
Please help.
Also, could you provide a reference to the correct format of the FormattedText method?
Thank you!
A.Acheson
Hi @0x3FA5
The issue here is that you need to edit the titleblock and then access the sketch, modify and then save on exit.
Option Explicit
Sub DrwScale()
Dim oSheet As Sheet
Dim oSketch As Sketch
Call oTitleBlock.Definition.Edit(oSketch)
Dim oTextBox As Inventor.TextBox
For Each oTextBox In oSketch.TextBoxes
    If InStr(oTextBox.FormattedText, "Scale") > 0 Then
        oTextBox.FormattedText = "<DerivedProperty DerivedID='29707'>Initial View Scale</DerivedProperty>"
Next
Call oTitleBlock.Definition.ExitEdit(True)
End Sub
Regards
Alan
0x3FA5
Thank you!
The only note, I wouldn't use "For Each", since there are other text boxes on the drawing that include the word "Scale", and I don't want to change all of them.
I figured that the box I need is Item(55).
'Macro Buttons
Option Explicit
Public Sub DrwScale()
    Dim oDrwDoc As DrawingDocument
    Set oDrwDoc = ThisApplication.ActiveDocument
    Dim oSheet As Sheet
    Set oSheet = oDrwDoc.ActiveSheet
    Dim oTitleBlockDef As TitleBlockDefinition
    Set oTitleBlockDef = oTitleBlock.Definition
    Dim oSketch As DrawingSketch
    Call oTitleBlockDef.Edit(oSketch)
    oSketch.TextBoxes.Item(55).FormattedText = _
    Call oTitleBlockDef.ExitEdit(oSketch)
    'oDrwDoc.Save
    'oDrwDoc.Close
End Sub
